Wolfgang_P 0 Posted August 5, 2022 Posted August 5, 2022 Hey there, i got the exact same problem. i also tryed older an newer emby versions. all the same scan problem. i think it could be a scraper.... dont know.
Wolfgang_P 0 Posted August 5, 2022 Author Posted August 5, 2022 (edited) a few details: - libary scan stops at around 90% - meta data is broken at new series/episodes - tryed older an newer emby versions Edited August 5, 2022 by Wolfgang_P
Luke 42186 Posted August 5, 2022 Posted August 5, 2022 6 minutes ago, Wolfgang_P said: a few details: - libary scan stops at around 90% - meta data is broken at new series/episodes - tryed older an newer emby versions Hi, why do you think metadata is broken? Please go over a specific example. Thanks.
Wolfgang_P 0 Posted August 5, 2022 Author Posted August 5, 2022 (edited) there 2 seperate errors: a) the missing metadata ist caused by the movie db scraper, others work b) the problem ahbi_santini is talking about is still there @Luke i thought this would be a connected to each other Edited August 5, 2022 by Wolfgang_P
Luke 42186 Posted August 5, 2022 Posted August 5, 2022 Please attach the information that I've requested above. Thanks.
Wolfgang_P 0 Posted August 5, 2022 Author Posted August 5, 2022 your request ist beyond my limited possibilities. may u need a log? some of this? embyserver.txt 5.8.2022, 19:39:45 hardware_detection-63795323319.txt 5.8.2022, 19:08:39 embyserver-63795323251.txt 5.8.2022, 19:07:31 hardware_detection-63795323144.txt 5.8.2022, 19:05:44 embyserver-63795322858.txt 5.8.2022, 19:00:58
Luke 42186 Posted August 5, 2022 Posted August 5, 2022 @Wolfgang_P please provide the log file from when the problem was experienced. Thanks.
