bmhanson 1 Posted August 4, 2022 Posted August 4, 2022 (edited) My apologies if this has been talked about but i tried searching and could not find anything. I updated to 4.7.6 and now one of my shows is not showing episodes int eh correct order. Previous to the update the episodes were in the correct order. To make it more confusion it is the one season of the show i had last been watching. I have not found any other shows displaying this issue yet. What might have caused the episodes to be out of order? I even just found other series that has the issue so it is not isolated to the one series. Though a number of them do appear to be correct. Previously in the season 1 listing it was the standard episode 1, 2, 3, etc. Now it is episode 10, 12, 13, 1, 2, 3... Quite vexing. I am not even sure where to start to figure out what happened. Edit: If it makes any difference i just noticed they are appearing out of order in the Metadata Manager also Edited August 4, 2022 by bmhanson additional information
Luke 42186 Posted August 5, 2022 Posted August 5, 2022 Hi there @bmhanson can you please provide a specific example, perhaps with screenshots to demonstrate? Thanks !
bmhanson 1 Posted August 5, 2022 Author Posted August 5, 2022 Sure. Here are a couple examples. From the season listing and corresponding Metadata manager. Let me know if this clears up my problem. I can try and get more when I get home if needed.
Luke 42186 Posted August 5, 2022 Posted August 5, 2022 OK if you refresh the metadata on the whole season 1, does that help?
bmhanson 1 Posted August 5, 2022 Author Posted August 5, 2022 No. I tried that when I first saw it was displaying differently in the metadata manager. Made no difference. I think the next thing I am going to try is deleting it and then readding it
bmhanson 1 Posted August 5, 2022 Author Posted August 5, 2022 OK. So deleting the season and readding it fixed the issue. BUT I really do not want to have to do that to all the shows that have this issue. I have a lot of stuff on here and going through all to see what had an issue and what doesn't is a lot of work. Add to that the delete/readd and I would really prefer to know why this happened and if there is another solution.
Luke 42186 Posted August 6, 2022 Posted August 6, 2022 1 hour ago, bmhanson said: No. I tried that when I first saw it was displaying differently in the metadata manager. Made no difference. I think the next thing I am going to try is deleting it and then readding it Did it help in the season listing though?
bmhanson 1 Posted August 6, 2022 Author Posted August 6, 2022 No. Refreshing the metadata made no difference. I do have others series with the same issue if there is something I need to try or data I need to gather.
Happy2Play 9800 Posted August 6, 2022 Posted August 6, 2022 Sounds like an old database issue and if refreshing item or Library is not correcting the issue then removing, scanning, and readding may be required to correct the database issue as already proven above.
bmhanson 1 Posted August 6, 2022 Author Posted August 6, 2022 Thanks for the help and info. I had hoped there would be an easier way. No idea why the update would have messed up the database. It was fine before I did that.
Luke 42186 Posted August 10, 2022 Posted August 10, 2022 Thanks for the feedback. We are looking into the original issue.
jluce50 122 Posted February 13, 2023 Posted February 13, 2023 On 8/10/2022 at 4:44 PM, Luke said: Thanks for the feedback. We are looking into the original issue. Just chiming in the say that this is still happening in 4.7.11.0. I've verified that all the metadata sources have it in the correct order and the metadata in Emby is correct.
Luke 42186 Posted February 14, 2023 Posted February 14, 2023 1 hour ago, jluce50 said: Just chiming in the say that this is still happening in 4.7.11.0. I've verified that all the metadata sources have it in the correct order and the metadata in Emby is correct. HI, that's odd. Is that the only place you're seeing that happen?
jluce50 122 Posted February 14, 2023 Posted February 14, 2023 8 minutes ago, Luke said: HI, that's odd. Is that the only place you're seeing that happen? It's the only place I've noticed it. Removing and then copying back the season folder fixed it. 2
