Mentalblaze 9 Posted August 3, 2022 Posted August 3, 2022 (edited) I have had a embyserver running as a container for a long on my old OpenMediaVault. Now I upgraded that to OMV 6 and I have been replacing the old compose files with new ones in Portainer. But I failed to replace the EmbyServer. The server was working with the old config but I made the mistake to remove the working container before I tried to start the new stack. The problem I get is this error: Deployment error failed to deploy a stack: Container embyserver Creating Error response from daemon: Unknown runtime specified nvidia I have a built in graphics on the motherboard and that is AMD based. So I am not sure if I should pursue installing the "nvidia-container-runtime", especially as I have problem with the commands I found for debian on github... I have tried to comment out the runtime: nvidia # Expose NVIDIA GPUs in the compose file, but that got me other errors instead. But I solved that issue, by removing these lines in the compose file: devices: - /dev/dri:/dev/dri # VAAPI/NVDEC/NVENC render nodes - /dev/vchiq:/dev/vchiq # MMAL/OMX on Raspberry Pi But that gives another question, is there something I should add there as "devices" to make the emby server work better? Edited August 3, 2022 by Mentalblaze
Luke 42245 Posted August 4, 2022 Posted August 4, 2022 Hi, work better how? is there something you're trying to solve?
Solution Mentalblaze 9 Posted August 4, 2022 Author Solution Posted August 4, 2022 I got it to work with a little back paddling. Commented out the "runtime: nvidia" and the second line in devices (that was for Raspberry pi) and changed network-mode to "bridge" so now it works. I tried to install the "nvidia-container-runtime" for debian, but got a bunch of errors. Maybe I try that again later to try and get better performance. But I leave it as is for now..
