VernoxVernax 4 Posted August 2, 2022 Posted August 2, 2022 Hello. Since subtitle extraction takes way too long for my system Embed is the only way I can do this. This is the DeviceProfile I am sending on post /PlaybackInfo: DeviceProfile: DeviceProfile { Name: "mpv", MaxStreamingBitrate: bitrate, TranscodingProfiles: [ TranscodingProfile { Container: "ts", Protocol: "hls", Type: "Video", VideoCodec: "hevc", } ], SubtitleProfiles: [ SubtitleProfile { Format: "subrip", Method: "Embed" }, SubtitleProfile { Format: "srt", Method: "Embed" }, SubtitleProfile { Format: "ass", Method: "Embed" }, SubtitleProfile { Format: "ssa", Method: "Embed" }, SubtitleProfile { Format: "pgssub", Method: "Embed" }, SubtitleProfile { Format: "sub", Method: "Embed" }, SubtitleProfile { Format: "dvdsub", Method: "Embed" }, SubtitleProfile { Format: "pgs", Method: "Embed" } ] } I've tried mutliple combinations spread across the last few days. I hope someone can point towards the solution. I have tried multiple video files containing either ass subtitles or subrips. Emby server log: log.txt
ebr 16332 Posted August 2, 2022 Posted August 2, 2022 Hi. Exactly what are you trying to accomplish? Those profile values are used to report to the server what your device supports, not what the server should necessarily do. If your device/app does not support embedded subtitles then they are not going to work.
pünktchen 1410 Posted August 2, 2022 Posted August 2, 2022 Do you want to burn-in the subtitles into the video stream? Then you want "encode" not "embed" because that's for video containers that can hold subtitles as a seperate stream like mkv.
Luke 42237 Posted August 2, 2022 Posted August 2, 2022 29 minutes ago, pünktchen said: Do you want to burn-in the subtitles into the video stream? Then you want "encode" not "embed" because that's for video containers that can hold subtitles as a seperate stream like mkv. You never need to specify Encode profiles because that's always supported, and that's always the fallback if no better technique is available.
Luke 42237 Posted August 2, 2022 Posted August 2, 2022 2 hours ago, VernoxVernax said: Hello. Since subtitle extraction takes way too long for my system Embed is the only way I can do this. This is the DeviceProfile I am sending on post /PlaybackInfo: DeviceProfile: DeviceProfile { Name: "mpv", MaxStreamingBitrate: bitrate, TranscodingProfiles: [ TranscodingProfile { Container: "ts", Protocol: "hls", Type: "Video", VideoCodec: "hevc", } ], SubtitleProfiles: [ SubtitleProfile { Format: "subrip", Method: "Embed" }, SubtitleProfile { Format: "srt", Method: "Embed" }, SubtitleProfile { Format: "ass", Method: "Embed" }, SubtitleProfile { Format: "ssa", Method: "Embed" }, SubtitleProfile { Format: "pgssub", Method: "Embed" }, SubtitleProfile { Format: "sub", Method: "Embed" }, SubtitleProfile { Format: "dvdsub", Method: "Embed" }, SubtitleProfile { Format: "pgs", Method: "Embed" } ] } I've tried mutliple combinations spread across the last few days. I hope someone can point towards the solution. I have tried multiple video files containing either ass subtitles or subrips. Emby server log: log.txt 3.69 kB · 0 downloads What happened and what did you expect to happen?
VernoxVernax 4 Posted August 3, 2022 Author Posted August 3, 2022 6 hours ago, Luke said: What happened and what did you expect to happen? Sorry, that I wasnt specific enough. I am trying to stream a transcoded video to my mpv player. The only reason for transcoding is or should be that the videos bitrate is too high for streaming. Since the video player is mpv, all subtitle codecs are supported and I would much rather just keep them Embeded in the video. This is why I specified all kinds of subtitle codecs in hopes of emby not always burning in the subtitles. External seemed to be suffice at the beginning but the extraction process took too long.
Luke 42237 Posted August 3, 2022 Posted August 3, 2022 OK it's because embeds are not used with hls transcoding. I would leave those Embed profiles in place, but also add: { Format: 'vtt', Method: 'Hls' } And then in your TranscodingProfile set ManifestSubtitles = 'vtt'; Now you'll get HLS subtitles, which the server fully supports, but then the next problem you'll run into is that this is not supported by mpv due to the hls demuxer in ffmpeg not having completed it's implementation of this.
VernoxVernax 4 Posted August 3, 2022 Author Posted August 3, 2022 12 hours ago, Luke said: OK it's because embeds are not used with hls transcoding. I would leave those Embed profiles in place, but also add: { Format: 'vtt', Method: 'Hls' } And then in your TranscodingProfile set ManifestSubtitles = 'vtt'; Now you'll get HLS subtitles, which the server fully supports, but then the next problem you'll run into is that this is not supported by mpv due to the hls demuxer in ffmpeg not having completed it's implementation of this. Why is it not possible to just copy the subtitle tracks like `-c:s copy -map 0:s`? Hls is not really necessary. I just tried to add whatever option, that could affect the transcode.
Luke 42237 Posted August 3, 2022 Posted August 3, 2022 Then try removing the hls protocol from your transcodingproifle.
VernoxVernax 4 Posted August 3, 2022 Author Posted August 3, 2022 Just now, Luke said: Then try removing the hls protocol from your transcodingproifle. Trust me I only added that after hours of confusion. *Removes it* Still doesnt work. Debug App: GetPostedPlaybackInfo request: {"Id":"42098","UserId":"b1384883b5904d67817a93c3b8804615","MaxStreamingBitrate":200000000,"StartTimeTicks":0,"DeviceProfile":{"Name":"mpv","Id":"12cdab97-934c-4c8b-85c7-8fde393b79a0","SupportedMediaTypes":"Audio,Photo,Video","MaxStreamingBitrate":200000000,"MusicStreamingTranscodingBitrate":256000,"MaxStaticMusicBitrate":999999999,"DirectPlayProfiles":[],"TranscodingProfiles":[{"Type":"Video","VideoCodec":"hevc","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0}],"ContainerProfiles":[],"CodecProfiles":[],"ResponseProfiles":[],"SubtitleProfiles":[{"Format":"subrip","Method":"Embed"},{"Format":"srt","Method":"Embed"},{"Format":"ass","Method":"Embed"},{"Format":"ssa","Method":"Embed"},{"Format":"pgssub","Method":"Embed"},{"Format":"sub","Method":"Embed"},{"Format":"dvdsub","Method":"Embed"},{"Format":"pgs","Method":"Embed"}]},"EnableDirectPlay":false,"EnableDirectStream":false,"EnableTranscoding":true,"AllowInterlacedVideoStreamCopy":false,"AllowVideoStreamCopy":false,"AllowAudioStreamCopy":true,"IsPlayback":true,"AutoOpenLiveStream":false,"DirectPlayProtocols":["Http"]} 2022-08-03 17:33:14.652 Info App: User policy for VernoxVernax. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2022-08-03 17:33:14.654 Info Server: http/1.1 Response 200 to emby_remote_ip. Time: 18ms. http://host1/emby/Items/42098/PlaybackInfo?UserId=b1384883b5904d67817a93c3b8804615 2022-08-03 17:33:14.663 Info Server: http/1.1 POST http://host1/emby/Sessions/Playing?format=json. UserAgent: curl/7.83.1-DEV isahc/1.7.2 2022-08-03 17:33:14.665 Debug SqliteItemRepository: Public GetItemLinks 2022-08-03 17:33:14.667 Info SessionManager: Playback start reported by app Emby Theater 0.5.7 playing movie. Started at unknown ms 2022-08-03 17:33:14.667 Info Server: http/1.1 Response 204 to emby_remote_ip. Time: 4ms. http://host1/emby/Sessions/Playing?format=json 2022-08-03 17:33:14.862 Info Server: http/1.1 GET http://host1/emby/videos/42098/stream?DeviceProfileId=12cdab97-934c-4c8b-85c7-8fde393b79a0&DeviceId=12cdab97-934c-4c8b-85c7-8fde393b79a0&MediaSourceId=9881ffd7131961084f78954549c288ca&PlaySessionId=0a7d84676aa94dceacbedd8c255eb531&VideoCodec=hevc&VideoBitrate=199552000&AudioBitrate=448000&AudioStreamIndex=4&SubtitleStreamIndex=1&SubtitleMethod=Encode&TranscodeReasons=DirectPlayError&allowVideoStreamCopy=false&Container=mkv&SubtitleMethod=VideoSideData.
Luke 42237 Posted August 3, 2022 Posted August 3, 2022 Please make sure to attach complete server and ffmpeg log file examples as these little snippets make it difficult to see the full picture. Thanks.
VernoxVernax 4 Posted August 3, 2022 Author Posted August 3, 2022 1 minute ago, Luke said: Please make sure to attach complete server and ffmpeg log file examples as these little snippets make it difficult to see the full picture. Thanks. Sorry. Btw thank you for still helping me. Many others would have already sent back to reading the docs. ffmpeg.log emby.log.txt
Luke 42237 Posted August 3, 2022 Posted August 3, 2022 I'm guessing you didn't specify a selected subtitle stream index in the /playbackinfo call.
VernoxVernax 4 Posted August 3, 2022 Author Posted August 3, 2022 2 minutes ago, Luke said: I'm guessing you didn't specify a selected subtitle stream index in the /playbackinfo call. You guessed correctly. I assumed emby would just return every track if I dont specify a single one. Didn't change a thing though: 2022-08-03 18:24:28.207 Debug App: GetPostedPlaybackInfo request: {"Id":"42098","UserId":"b1384883b5904d67817a93c3b8804615","MaxStreamingBitrate":20000000,"StartTimeTicks":0,"SubtitleStreamIndex":0,"DeviceProfile":{"Name":"mpv","Id":"12cdab97-934c-4c8b-85c7-8fde393b79a0","SupportedMediaTypes":"Audio,Photo,Video","MaxStreamingBitrate":20000000,"MusicStreamingTranscodingBitrate":256000,"MaxStaticMusicBitrate":999999999,"DirectPlayProfiles":[],"TranscodingProfiles":[{"Type":"Video","VideoCodec":"hevc","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false,"AllowInterlacedVideoStreamCopy":false,"MaxManifestSubtitles":0}],"ContainerProfiles":[],"CodecProfiles":[],"ResponseProfiles":[],"SubtitleProfiles":[{"Format":"subrip","Method":"Embed"},{"Format":"srt","Method":"Embed"},{"Format":"ass","Method":"Embed"},{"Format":"ssa","Method":"Embed"},{"Format":"pgssub","Method":"Embed"},{"Format":"sub","Method":"Embed"},{"Format":"dvdsub","Method":"Embed"},{"Format":"pgs","Method":"Embed"}]},"EnableDirectPlay":false,"EnableDirectStream":false,"EnableTranscoding":true,"AllowInterlacedVideoStreamCopy":false,"AllowVideoStreamCopy":false,"AllowAudioStreamCopy":true,"IsPlayback":true,"AutoOpenLiveStream":false,"DirectPlayProtocols":["Http"]} 2022-08-03 18:24:28.211 Info App: User policy for VernoxVernax. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True ffmpeg.log
Luke 42237 Posted August 3, 2022 Posted August 3, 2022 You're not specifying a container in your TranscodingProfile
VernoxVernax 4 Posted August 3, 2022 Author Posted August 3, 2022 2 minutes ago, Luke said: You're not specifying a container in your TranscodingProfile oh. I just added "&Container=mkv" to the url and since that worked I assumed it wouldn't have an impact on the subtitle mode. Well its obviously working now. While I am already at it: I assume its not possible to mux and copy every track into the file (except for video of course). Like every subtitle track and audio track. Without the "index" options, it just takes the default one, which is fine, but not to my liking.
Luke 42237 Posted August 3, 2022 Posted August 3, 2022 That's not exactly supported, no. You might be able to take the transcoding url obtained from /playbackInfo and do a search and replace on SubtitleStreamIndex and change it to SubtitleStreamIndexes=1,2,3, so a comma delimited list. But that's untested by us so I can't promise it will work. 1
VernoxVernax 4 Posted August 3, 2022 Author Posted August 3, 2022 1 minute ago, Luke said: That's not exactly supported, no. You might be able to take the transcoding url obtained from /playbackInfo and do a search and replace on SubtitleStreamIndex and change it to SubtitleStreamIndexes=1,2,3, so a comma delimited list. But that's untested by us so I can't promise it will work. Great. Will try. Thank you so much for helping me!
VernoxVernax 4 Posted August 6, 2022 Author Posted August 6, 2022 Well, after I realised the SubtitleStreamIndex option wasn't working, it took me like 5 hours only to find out that one also has to provide the mediasourceid. Changing/appending "es" to SubtitleStreamIndex and turning "1" to "1,2,3", yields in the whole argument missing from "Debug App: GetPostedPlaybackInfo request" (log). Just tried turning the string to an array (like ["1", "2", "3"] or [1,2,3]). Nothing.
