HawkXP71 112 Posted August 2, 2022 Posted August 2, 2022 I have an app working, that Im happy with the functionality of. It syncs user data (play status, favorites etc) between two servers. I would like to convert this into an Emby Plugin. Right now its a desktop application. Im looking to get some help in the conversion. All of it is open source, none of it is proprietary, and I have no desire to use it for any financial gain. It started as a personal need, and I figured it might be useful to others. Feel free to check out the current project here: https://github.com/towel42-com/EmbySync Thanks in Advanced -hawk 2
Luke 42237 Posted August 3, 2022 Posted August 3, 2022 Hi, what is the advantage of a plugin compared to a standalone app?
HawkXP71 112 Posted August 3, 2022 Author Posted August 3, 2022 (edited) 2 minutes ago, Luke said: Hi, what is the advantage of a plugin compared to a standalone app? Honestly, twofold. I would set it to run once a day, and keep them automatically in sync. Or to update on a play by a user. Depending on the triggers available Secone as a learning experiment for me Edited August 3, 2022 by HawkXP71
Luke 42237 Posted August 3, 2022 Posted August 3, 2022 You could also do that with webhooks and an external application.
HawkXP71 112 Posted August 3, 2022 Author Posted August 3, 2022 40 minutes ago, Luke said: You could also do that with webhooks and an external application. Yes, but I would think the plugin would integrate a bit tighter But doing it that way, I can simply port the app to the host servers platform, put it in a docker and be done.
Cheesegeezer 3106 Posted August 8, 2022 Posted August 8, 2022 Hi Hawk, i can port to a plugin if you want me to help. I can show you the structure and requirements and set up the Scheduled tasks also. will probably require some refactoring to directly access the emby interfaces from the plugin. But should be good
Cheesegeezer 3106 Posted August 8, 2022 Posted August 8, 2022 On 03/08/2022 at 04:27, Luke said: You could also do that with webhooks and an external application. The internal tasks you created Luke are quite a powerful automation tool.
Cheesegeezer 3106 Posted August 8, 2022 Posted August 8, 2022 5 minutes ago, chef said: Oh a c++ developer. Hello Hahahaha i didn't even check out the project. never even looked at c++ (is it difficult) 1
Cheesegeezer 3106 Posted August 8, 2022 Posted August 8, 2022 Wooooooooooooooooooooaaaah..... @chef That scares me somewhat!! 1
TeamB 2440 Posted August 8, 2022 Posted August 8, 2022 Its a lower level language and more unforgiving in a few ways but has most of the same constructs like arrays, lists, maps etc as c# so it should feel somewhat familiar.
ebr 16332 Posted August 8, 2022 Posted August 8, 2022 15 minutes ago, TeamB said: and more unforgiving in a few ways That might be an understatement . Most managed-code developers have no concept of memory management which will likely bite them.
chef 3811 Posted August 8, 2022 Posted August 8, 2022 (edited) @HawkXP71 Most of the users who have posted here this morning have GitHub repos with entire plugin layouts. It's written in c#. Mine is: chefbennyj1 And most of us have worked together on plugins in the past, we we are all grouped on GitHub (at some point) as collaboraters. You should be able to follow the user rabbit hole to find useful stuff. One user leading to another. Let us know how you get on with it. Edited August 8, 2022 by chef 1
TeamB 2440 Posted August 8, 2022 Posted August 8, 2022 Here is the doc to get started, it will give you a bare bones plugin you can load in the server. https://github.com/MediaBrowser/Emby/wiki/How-to-build-a-Server-Plugin You can then add, scheduled tasks, rest api endpoints, interface pages etc. As mentioned there are a number of examples in github, here are two of mine. https://github.com/faush01/playback_reporting https://github.com/faush01/ChapterApi
Cheesegeezer 3106 Posted August 8, 2022 Posted August 8, 2022 4 minutes ago, TeamB said: Here is the doc to get started, it will give you a bare bones plugin you can load in the server. https://github.com/MediaBrowser/Emby/wiki/How-to-build-a-Server-Plugin You can then add, scheduled tasks, rest api endpoints, interface pages etc. As mentioned there are a number of examples in github, here are two of mine. https://github.com/faush01/playback_reporting https://github.com/faush01/ChapterApi We are on it TeamB, but thanks.
Junglejim 385 Posted August 13, 2022 Posted August 13, 2022 (edited) It's not that hard, most dev's cut there teeth on this sort of stuff. If you load up the lib's you need in the header you should be good to go. From there it's just programming logic, it might take some time to get used to the syntax.. but not that long. Edited August 13, 2022 by Junglejim
BillOatman 597 Posted August 25, 2022 Posted August 25, 2022 On 8/8/2022 at 9:34 AM, ebr said: That might be an understatement . Most managed-code developers have no concept of memory management which will likely bite them. Real men (and women) do their own memory management!
HawkXP71 112 Posted August 25, 2022 Author Posted August 25, 2022 24 minutes ago, BillOatman said: Real men (and women) do their own memory management! Amen brother!
HawkXP71 112 Posted August 25, 2022 Author Posted August 25, 2022 44 minutes ago, chef said: I can call GC.Collect()... I can call exit( -1 ) to clear all memory.. its not exactly memory management 1
