ebr 16337 Posted August 7, 2022 Posted August 7, 2022 20 hours ago, ChaoOos said: i tested another movie before and its working So it could just be intermittent network issues or latency.
ChaoOos 2 Posted August 8, 2022 Author Posted August 8, 2022 20 hours ago, ebr said: So it could just be intermittent network issues or latency. Maybe I can test it personally now. I started more 4k movies. All working except spiderman User:Odo Time: 06:24-06:27 Dv Version 5 is working too.Â
ebr 16337 Posted August 8, 2022 Posted August 8, 2022 1 hour ago, ChaoOos said: I started more 4k movies. All working except spiderman Your log still shows timeouts. Maybe it is that particular file or its location. Can you try remuxing it by running it through mkvtoolnix or moving its location to another physical drive?
ChaoOos 2 Posted August 9, 2022 Author Posted August 9, 2022 On 8/4/2022 at 4:14 AM, Luke said: HI, can you try sideloading our standard android app on the same device and let us know how it compares? https://emby.media/emby-for-android.html Thanks. How can i install the normal android app on philips TV? Via Google Store only Android TV i can install (normal android is incompatible). Adb is complicated
ebr 16337 Posted August 9, 2022 Posted August 9, 2022 43 minutes ago, ChaoOos said: How can i install the normal android app on philips TV? Hi. Can you try this?
ChaoOos 2 Posted August 9, 2022 Author Posted August 9, 2022 58 minutes ago, ebr said: Hi. Can you try this? i try it in a few weeks, because the TV of my parents and my NAS (and my FireTVStick) are 500km apart And yea, i have a certificate problem i try to correct it, when i'm at home. Who can i ask if i need help with synology Lets Crypt and create a .p12 file? I don't know why the logs show i have network issues, but i don't think thats the problem I have attached 3 logs: ...Father of Bride and ...Everything started. But Spider-Man not. Why DV 7 dont fallback to HDR10?  ffmpeg-transcode-dbeedba6-56b2-4a91-af5f-70e3560783b7_1_Father of bride.txt ffmpeg-transcode-da0cf125-4100-415c-a10d-a3493896877e_1_Spiderman.txt ffmpeg-transcode-fd5b6e33-692e-409f-ae45-5deabfc5fff7_1_everything.txt
ChaoOos 2 Posted August 9, 2022 Author Posted August 9, 2022 I just noticed that the 4k movies get stuck in HTTPS. The films run smoothly in HTTP. Here is the comparison. ffmpeg-transcode-e2542d41-b6f1-42b1-bbff-ec48350ad536_1_Everything_HTTPS.txtffmpeg-transcode-552d0d34-8fd9-45e6-b350-38c85d00c012_1_Everything_HTTP.txt
ebr 16337 Posted August 10, 2022 Posted August 10, 2022 17 hours ago, ChaoOos said: I just noticed that the 4k movies get stuck in HTTPS. The films run smoothly in HTTP. Then, this may very well be the root of all your issues: 17 hours ago, ChaoOos said: And yea, i have a certificate problem Â
ebr 16337 Posted August 10, 2022 Posted August 10, 2022 On 8/2/2022 at 1:05 PM, ebr said: Hi. I believe this is your issue: 08-02 17:27:42.377 12354 13686 I System.out: Web socket error. 08-02 17:27:42.377 12354 13686 I System.out: Unacceptable certificate: CN=R3, O=Let's Encrypt, C=US  It is either expired or not constructed properly. Possibly the issue with Lets encrypt that originated last October...
ChaoOos 2 Posted August 10, 2022 Author Posted August 10, 2022 30 minutes ago, ebr said: It is either expired or not constructed properly. Possibly the issue with Lets encrypt that originated last October... I have the certificate from synology Letscript and combine it per OpenSSL to .p12 file Like: openssl pkcs12 -export -out certificate.p12 -inkey privkey.pem -in cert.pem -certfile chain.pem with a password Is it right and how often do I have to do this? I felt there was a problem with the Intermediates certificate. After the emby update that "the SSL certificates are ignored", I lost sight of the topic. It worked again  6 hours ago, ebr said: Then, this may very well be the root of all your issues:  Yea for the lags, but not the problem for spider-man (DOVI profile7). Spider-Man does not start on HTTP or HTTPS.  Today I'm on another external network and was able to test it with a FireTV Stick. I have no lags with HTTPS (other movies) and the Spiderman movie doesn't start either. User: Georg Logtime: 13:29 (20:39 in Germany)  I thank you for your help and support. I try to give you as much information as I can
ChaoOos 2 Posted August 10, 2022 Author Posted August 10, 2022 On 8/9/2022 at 10:43 PM, ChaoOos said: I just noticed that the 4k movies get stuck in HTTPS. The films run smoothly in HTTP. Here is the comparison. ffmpeg-transcode-e2542d41-b6f1-42b1-bbff-ec48350ad536_1_Everything_HTTPS.txt 48.89 kB · 0 downloads ffmpeg-transcode-552d0d34-8fd9-45e6-b350-38c85d00c012_1_Everything_HTTP.txt 56.42 kB · 0 downloads This is a 4k movie thats works. not Spider-Man The lags only happened to my parents. Today in the other network the lags did not occur. Here I only have the FireTV Stick on an HD TV. My parents have a 4k TV and use the internal app.
ebr 16337 Posted August 10, 2022 Posted August 10, 2022 Okay, then I believe we are back to an issue with that particular file: On 8/8/2022 at 9:50 AM, ebr said: Your log still shows timeouts. Maybe it is that particular file or its location. Can you try remuxing it by running it through mkvtoolnix or moving its location to another physical drive? Â
ChaoOos 2 Posted August 11, 2022 Author Posted August 11, 2022 (edited) 23 hours ago, ebr said: Okay, then I believe we are back to an issue with that particular file:  I'm at home and i tried Spider-man 4K with my FireTV stick in Internal Network. It's working. I'm going on vacation tomorrow. After that I will test other DOVI Profil 7 films and will remux Spider-Man. New Report for internal Test User: Chaooos Time: 15:41 (22:41)  Edited August 11, 2022 by ChaoOos
Luke 42245 Posted August 24, 2022 Posted August 24, 2022 @ChaoOos are you still having an issue with this?
ChaoOos 2 Posted August 26, 2022 Author Posted August 26, 2022 On 8/24/2022 at 3:53 AM, Luke said: @ChaoOos are you still having an issue with this? Yes and no I updated the certificates. Additionally, I resized the movie with StaxRip and removed Dolby Vision. The test is still pending. My mom wanted to try it today I'll report back afterwards. 1
ChaoOos 2 Posted September 4, 2022 Author Posted September 4, 2022 On 8/26/2022 at 6:45 PM, ChaoOos said: Yes and no I updated the certificates. Additionally, I resized the movie with StaxRip and removed Dolby Vision. The test is still pending. My mom wanted to try it today I'll report back afterwards. Hello, I tested it myself today because my mother had no time All my 3 DoVi 7 movies are working now. We can close the topic. Thanks for your help and patience Was it really because of the certificate? All other movies worked.
