ChaoOos 2 Posted August 1, 2022 Posted August 1, 2022 Hello guys, I have the problem that some 4k movies don't start. It starts loading and then stops. It's a Philips TV with Android TV 2.0.77g. An example is Spiderman. Log: ffmpeg-transcode-1721a80c-8eee-4a4c-9171-f3d2902d6d02_1.txt Some 4k movies work. In the internal network I can start the film. thx 4 help
Happy2Play 9812 Posted August 2, 2022 Posted August 2, 2022 Is this a issue only with DOVI content? DOVI configuration record: version: 1.0, profile: 7, level: 6, rpu flag: 1, el flag: 1, bl flag: 1, compatibility id: 6 21:45:40.102 [hevc @ 0x185f2c0] get_buffer() failed 21:45:40.102 [hevc @ 0x185f2c0] thread_get_buffer() failed 21:45:40.102 [hevc @ 0x185f2c0] Error parsing NAL unit #2. 21:45:40.102 [hevc @ 0x1866000] Multiple Dolby Vision RPUs found in one AU. Skipping previous.
Happy2Play 9812 Posted August 2, 2022 Posted August 2, 2022 2 hours ago, ChaoOos said: What is DOVI content? Dolby Vision as it has different requirements the normal HDR10. @FrostBytecan you comment more on this?
FrostByte 5454 Posted August 2, 2022 Posted August 2, 2022 (edited) Dolby Vision (DoVi or DV) profile 7 is comprised of Enhanced, RPU and HDR10 layers and is what you find on 4K UHD discs. DV profile 7 is designed so that HDR TVs which don't support DV can still play the HDR10 layer and still display a HDR picture while throwing out the rest. However, most DV TVs don't support DV profile 7 when played from internal apps because as I mentioned that was originally designed for UHD discs. Most apps when played by the actual TV only support DV profile 5 or profile 8. Though they should just throw out the DV parts when playing profile 7. What's strange about the error is that I think it's saying there are 2 RPUs in the one network abstraction layer unit (NALU). The RPU is the metadata which controls things like different luminance of scenes, etc. If I were to guess is that the TV just doesn't support DV7 and just not reverting to HDR10 so that's the error you're getting. You could try some DV profile 5 or profile 8 material and see if they work. That's just a WAG though and something you could try. Or, try other DV profile 7 material. However, you should really send the internal logs to @ebr right after you get the error. I'm sure he knows a lot more than me. Edited August 2, 2022 by FrostByte
ChaoOos 2 Posted August 2, 2022 Author Posted August 2, 2022 ah ok. thx for the explanation. HDR Format for this movie: Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible Full Media Info: Spoiler Allgemein Unique ID : 248974083621294912028045093271287968889 (0xBB4EAA0FB68B75CB38C947CB37D13479) Vollständiger Name : Y:\Emby Media\Filme\=Marvel=\Spider-Man No Way Home (2021) 2160p DTS-MA\Spider-Man No Way Home (2021) 2160p DTS-MA.mkv Format : Matroska Format-Version : Version 4 Dateigröße : 41,1 GiB Dauer : 2 h 28 min Modus der Gesamtbitrate : variabel Gesamte Bitrate : 39,7 Mb/s Filmname : Spider-Man: No Way Home (2021) Kodierungs-Datum : UTC 2022-04-07 17:16:04 Kodierendes Programm : mkvmerge v63.0.0 ('Everything') 64-bit verwendete Encoder-Bibliothek : libebml v1.4.2 + libmatroska v1.6.4 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format-Profil : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible Codec-ID : V_MPEGH/ISO/HEVC Dauer : 2 h 28 min Bitrate : 31,1 Mb/s Breite : 3 840 Pixel Höhe : 1 608 Pixel Bildseitenverhältnis : 2,40:1 Modus der Bildwiederholungsrate : konstant Bildwiederholungsrate : 23,976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.210 Stream-Größe : 32,2 GiB (78%) verwendete Encoder-Bibliothek : x265 3.5+35-e3713124d:[Windows][GCC 11.2.0][64 bit] 10bit Kodierungseinstellungen : cpuid=1111039 / frame-threads=5 / numa-pools=32 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1608 / interlace=0 / total-frames=213144 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / no-eob / no-eos / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / no-hist-scenecut / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=7.5 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / min-vbv-fullness=50.0 / max-vbv-fullness=80.0 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(8500,39850)B(6550,2300)R(35400,14600)WP(15635,16450)L(10000000,01) / cll=9978,867 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass Default : Ja Forced : Nein Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.2020 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 9978 cd/m2 Maximum Frame-Average Light Level : 867 cd/m2 Audio #1 ID : 2 Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec-ID : A_DTS Dauer : 2 h 28 min Bitraten-Modus : variabel Bitrate : 2 210 kb/s Kanäle : 6 Kanäle Channel layout : C L R Ls Rs LFE Samplingrate : 48,0 kHz Bildwiederholungsrate : 93,750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless Stream-Größe : 2,29 GiB (6%) Titel : DTS-HD MA 5.1 @ 2210 kbps Sprache : Deutsch Default : Ja Forced : Nein Audio #2 ID : 3 ID in the original source medium : 4352 (0x1100) Format : MLP FBA 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Codec-ID : A_TRUEHD Dauer : 2 h 28 min Bitraten-Modus : variabel Bitrate : 4 054 kb/s maximale Bitrate : 7 548 kb/s Kanäle : 8 Kanäle Channel layout : L R C LFE Ls Rs Lb Rb Samplingrate : 48,0 kHz Bildwiederholungsrate : 1 200,000 FPS (40 SPF) Bit depth : 24 bits Compression mode : Lossless Video Verzögerung : 10 ms Stream-Größe : 4,20 GiB (10%) Titel : TrueHD 7.1 @ 4054 kbps [Atmos] Sprache : Englisch Default : Nein Forced : Nein Originales Source-Medium : Blu-ray Number of dynamic objects : 11 Bed channel count : 1 Kanal Bed channel configuration : LFE Audio #3 ID : 4 Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec-ID : A_DTS Dauer : 2 h 28 min Bitraten-Modus : variabel Bitrate : 2 200 kb/s Kanäle : 6 Kanäle Channel layout : C L R Ls Rs LFE Samplingrate : 48,0 kHz Bildwiederholungsrate : 93,750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless Stream-Größe : 2,28 GiB (6%) Titel : DTS-HD MA 5.1 @ 2200 kbps Sprache : Englisch Default : Nein Forced : Nein Text #1 ID : 5 Format : PGS Muxing-Modus : zlib Codec-ID : S_HDMV/PGS Codec-ID/Info : Picture based subtitle format used on BDs/HD-DVDs Dauer : 16 min 33s Bitrate : 1 074 b/s Count of elements : 8 Stream-Größe : 130 KiB (0%) Titel : German forced [PGS] Sprache : Deutsch Default : Ja Forced : Ja Text #2 ID : 6 Format : PGS Muxing-Modus : zlib Codec-ID : S_HDMV/PGS Codec-ID/Info : Picture based subtitle format used on BDs/HD-DVDs Dauer : 2 h 28 min Bitrate : 34,1 kb/s Count of elements : 3800 Stream-Größe : 36,1 MiB (0%) Titel : German full [PGS] Sprache : Deutsch Default : Nein Forced : Nein Text #3 ID : 7 Format : PGS Muxing-Modus : zlib Codec-ID : S_HDMV/PGS Codec-ID/Info : Picture based subtitle format used on BDs/HD-DVDs Dauer : 2 h 27 min Bitrate : 35,3 kb/s Count of elements : 3833 Stream-Größe : 37,4 MiB (0%) Titel : English full [PGS] Sprache : Englisch Default : Nein Forced : Nein Text #4 ID : 8 Format : PGS Muxing-Modus : zlib Codec-ID : S_HDMV/PGS Codec-ID/Info : Picture based subtitle format used on BDs/HD-DVDs Dauer : 2 h 27 min Bitrate : 41,5 kb/s Count of elements : 4404 Stream-Größe : 43,9 MiB (0%) Titel : English SDH [PGS] Sprache : Englisch Default : Nein Forced : Nein Text #5 ID : 9 Format : UTF-8 Codec-ID : S_TEXT/UTF8 Codec-ID/Info : UTF-8 Plain Text Dauer : 16 min 33s Bitrate : 1 b/s Count of elements : 4 Stream-Größe : 168 Bytes (0%) Titel : German forced [SRT] Sprache : Deutsch Default : Nein Forced : Ja Text #6 ID : 10 Format : UTF-8 Codec-ID : S_TEXT/UTF8 Codec-ID/Info : UTF-8 Plain Text Dauer : 2 h 28 min Bitrate : 53 b/s Count of elements : 1900 Stream-Größe : 58,3 KiB (0%) Titel : German full [SRT] Sprache : Deutsch Default : Nein Forced : Nein Text #7 ID : 11 Format : UTF-8 Codec-ID : S_TEXT/UTF8 Codec-ID/Info : UTF-8 Plain Text Dauer : 2 h 27 min Bitrate : 61 b/s Count of elements : 2015 Stream-Größe : 66,9 KiB (0%) Titel : English full [SRT] Sprache : Englisch Default : Nein Forced : Nein Menü 00:00:00.000 : 00:00:00.000 00:05:03.178 : 00:05:03.178 00:11:58.593 : 00:11:58.593 00:18:38.909 : 00:18:38.909 00:27:00.452 : 00:27:00.452 00:37:21.239 : 00:37:21.239 00:48:02.004 : 00:48:02.004 00:59:51.797 : 00:59:51.797 01:04:06.634 : 01:04:06.634 01:09:51.312 : 01:09:51.312 01:18:29.455 : 01:18:29.455 01:28:59.626 : 01:28:59.626 01:33:48.289 : 01:33:48.289 01:46:38.392 : 01:46:38.392 02:05:39.323 : 02:05:39.323 02:13:03.601 : 02:13:03.601 Tonight I'm testing other films, but what I noticed: doesn't work: Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible (is it Profile 8?) work: SMPTE ST 2086, HDR10 compatible I will check it again and confirm/correct it.
FrostByte 5454 Posted August 2, 2022 Posted August 2, 2022 34 minutes ago, ChaoOos said: ah ok. thx for the explanation. HDR Format for this movie: Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible Full Media Info: Reveal hidden contents Allgemein Unique ID : 248974083621294912028045093271287968889 (0xBB4EAA0FB68B75CB38C947CB37D13479) Vollständiger Name : Y:\Emby Media\Filme\=Marvel=\Spider-Man No Way Home (2021) 2160p DTS-MA\Spider-Man No Way Home (2021) 2160p DTS-MA.mkv Format : Matroska Format-Version : Version 4 Dateigröße : 41,1 GiB Dauer : 2 h 28 min Modus der Gesamtbitrate : variabel Gesamte Bitrate : 39,7 Mb/s Filmname : Spider-Man: No Way Home (2021) Kodierungs-Datum : UTC 2022-04-07 17:16:04 Kodierendes Programm : mkvmerge v63.0.0 ('Everything') 64-bit verwendete Encoder-Bibliothek : libebml v1.4.2 + libmatroska v1.6.4 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format-Profil : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible Codec-ID : V_MPEGH/ISO/HEVC Dauer : 2 h 28 min Bitrate : 31,1 Mb/s Breite : 3 840 Pixel Höhe : 1 608 Pixel Bildseitenverhältnis : 2,40:1 Modus der Bildwiederholungsrate : konstant Bildwiederholungsrate : 23,976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.210 Stream-Größe : 32,2 GiB (78%) verwendete Encoder-Bibliothek : x265 3.5+35-e3713124d:[Windows][GCC 11.2.0][64 bit] 10bit Kodierungseinstellungen : cpuid=1111039 / frame-threads=5 / numa-pools=32 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1608 / interlace=0 / total-frames=213144 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / no-eob / no-eos / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / no-hist-scenecut / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=7.5 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / min-vbv-fullness=50.0 / max-vbv-fullness=80.0 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(8500,39850)B(6550,2300)R(35400,14600)WP(15635,16450)L(10000000,01) / cll=9978,867 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass Default : Ja Forced : Nein Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.2020 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 9978 cd/m2 Maximum Frame-Average Light Level : 867 cd/m2 Audio #1 ID : 2 Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec-ID : A_DTS Dauer : 2 h 28 min Bitraten-Modus : variabel Bitrate : 2 210 kb/s Kanäle : 6 Kanäle Channel layout : C L R Ls Rs LFE Samplingrate : 48,0 kHz Bildwiederholungsrate : 93,750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless Stream-Größe : 2,29 GiB (6%) Titel : DTS-HD MA 5.1 @ 2210 kbps Sprache : Deutsch Default : Ja Forced : Nein Audio #2 ID : 3 ID in the original source medium : 4352 (0x1100) Format : MLP FBA 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Codec-ID : A_TRUEHD Dauer : 2 h 28 min Bitraten-Modus : variabel Bitrate : 4 054 kb/s maximale Bitrate : 7 548 kb/s Kanäle : 8 Kanäle Channel layout : L R C LFE Ls Rs Lb Rb Samplingrate : 48,0 kHz Bildwiederholungsrate : 1 200,000 FPS (40 SPF) Bit depth : 24 bits Compression mode : Lossless Video Verzögerung : 10 ms Stream-Größe : 4,20 GiB (10%) Titel : TrueHD 7.1 @ 4054 kbps [Atmos] Sprache : Englisch Default : Nein Forced : Nein Originales Source-Medium : Blu-ray Number of dynamic objects : 11 Bed channel count : 1 Kanal Bed channel configuration : LFE Audio #3 ID : 4 Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec-ID : A_DTS Dauer : 2 h 28 min Bitraten-Modus : variabel Bitrate : 2 200 kb/s Kanäle : 6 Kanäle Channel layout : C L R Ls Rs LFE Samplingrate : 48,0 kHz Bildwiederholungsrate : 93,750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless Stream-Größe : 2,28 GiB (6%) Titel : DTS-HD MA 5.1 @ 2200 kbps Sprache : Englisch Default : Nein Forced : Nein Text #1 ID : 5 Format : PGS Muxing-Modus : zlib Codec-ID : S_HDMV/PGS Codec-ID/Info : Picture based subtitle format used on BDs/HD-DVDs Dauer : 16 min 33s Bitrate : 1 074 b/s Count of elements : 8 Stream-Größe : 130 KiB (0%) Titel : German forced [PGS] Sprache : Deutsch Default : Ja Forced : Ja Text #2 ID : 6 Format : PGS Muxing-Modus : zlib Codec-ID : S_HDMV/PGS Codec-ID/Info : Picture based subtitle format used on BDs/HD-DVDs Dauer : 2 h 28 min Bitrate : 34,1 kb/s Count of elements : 3800 Stream-Größe : 36,1 MiB (0%) Titel : German full [PGS] Sprache : Deutsch Default : Nein Forced : Nein Text #3 ID : 7 Format : PGS Muxing-Modus : zlib Codec-ID : S_HDMV/PGS Codec-ID/Info : Picture based subtitle format used on BDs/HD-DVDs Dauer : 2 h 27 min Bitrate : 35,3 kb/s Count of elements : 3833 Stream-Größe : 37,4 MiB (0%) Titel : English full [PGS] Sprache : Englisch Default : Nein Forced : Nein Text #4 ID : 8 Format : PGS Muxing-Modus : zlib Codec-ID : S_HDMV/PGS Codec-ID/Info : Picture based subtitle format used on BDs/HD-DVDs Dauer : 2 h 27 min Bitrate : 41,5 kb/s Count of elements : 4404 Stream-Größe : 43,9 MiB (0%) Titel : English SDH [PGS] Sprache : Englisch Default : Nein Forced : Nein Text #5 ID : 9 Format : UTF-8 Codec-ID : S_TEXT/UTF8 Codec-ID/Info : UTF-8 Plain Text Dauer : 16 min 33s Bitrate : 1 b/s Count of elements : 4 Stream-Größe : 168 Bytes (0%) Titel : German forced [SRT] Sprache : Deutsch Default : Nein Forced : Ja Text #6 ID : 10 Format : UTF-8 Codec-ID : S_TEXT/UTF8 Codec-ID/Info : UTF-8 Plain Text Dauer : 2 h 28 min Bitrate : 53 b/s Count of elements : 1900 Stream-Größe : 58,3 KiB (0%) Titel : German full [SRT] Sprache : Deutsch Default : Nein Forced : Nein Text #7 ID : 11 Format : UTF-8 Codec-ID : S_TEXT/UTF8 Codec-ID/Info : UTF-8 Plain Text Dauer : 2 h 27 min Bitrate : 61 b/s Count of elements : 2015 Stream-Größe : 66,9 KiB (0%) Titel : English full [SRT] Sprache : Englisch Default : Nein Forced : Nein Menü 00:00:00.000 : 00:00:00.000 00:05:03.178 : 00:05:03.178 00:11:58.593 : 00:11:58.593 00:18:38.909 : 00:18:38.909 00:27:00.452 : 00:27:00.452 00:37:21.239 : 00:37:21.239 00:48:02.004 : 00:48:02.004 00:59:51.797 : 00:59:51.797 01:04:06.634 : 01:04:06.634 01:09:51.312 : 01:09:51.312 01:18:29.455 : 01:18:29.455 01:28:59.626 : 01:28:59.626 01:33:48.289 : 01:33:48.289 01:46:38.392 : 01:46:38.392 02:05:39.323 : 02:05:39.323 02:13:03.601 : 02:13:03.601 Tonight I'm testing other films, but what I noticed: doesn't work: Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible (is it Profile 8?) work: SMPTE ST 2086, HDR10 compatible I will check it again and confirm/correct it. Yes, that's DV profile 8 which has a HDR10 backup track also. See if you can find a DV profile 5 format movie or show. Profile 5 is for things like Disney+, Netflix, etc and has no HDR10 layer at all, just the DV layers. Basically, all the streaming services use DV5 and if your TV supports DV then it should at least support profile 5 when played from an internal app. Post what you find. Internal logs of course will help. If the DV profile 7/8 is the issue, then I would think it should at least fallback to the HDR10 layer of those two profiles.
ebr 16337 Posted August 2, 2022 Posted August 2, 2022 14 hours ago, ChaoOos said: It starts loading and then stops. Can you please reproduce that and then follow the instructions to send a log from the app? Thanks.
ChaoOos 2 Posted August 2, 2022 Author Posted August 2, 2022 1 hour ago, ebr said: Can you please reproduce that and then follow the instructions to send a log from the app? Thanks. Exactly what you were doing and what happened. Include the name of whatever you played if it is a playback problem I start emby, search Spider-Man and start the movie. i wait and see the circle for loading and nothing happens The time you sent the log (in Eastern Time please - UTC -5) 10:30 (17:30 in Germany) The name of the Emby user on the local server that was logged in at the time OdoundBritta
ChaoOos 2 Posted August 2, 2022 Author Posted August 2, 2022 2 hours ago, FrostByte said: Yes, that's DV profile 8 which has a HDR10 backup track also. See if you can find a DV profile 5 format movie or show. Profile 5 is for things like Disney+, Netflix, etc and has no HDR10 layer at all, just the DV layers. Basically, all the streaming services use DV5 and if your TV supports DV then it should at least support profile 5 when played from an internal app. Post what you find. Internal logs of course will help. If the DV profile 7/8 is the issue, then I would think it should at least fallback to the HDR10 layer of those two profiles. I don't have movies with profile 5. I try it, if I get one. Profile 8 Movies are working: "Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible"
FrostByte 5454 Posted August 2, 2022 Posted August 2, 2022 52 minutes ago, ChaoOos said: Profile 8 Movies are working: "Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible" That's good, because there is at least one streaming service (Bravia Core) which streams DV profile 8. Try to get those logs to the devs though, that would be the only way to know for sure. It's just that most TVs don't support DV7 internally and require an external box like an UHD player or Shield in order to play DV7.
ebr 16337 Posted August 2, 2022 Posted August 2, 2022 Hi. I believe this is your issue: 08-02 17:27:42.377 12354 13686 I System.out: Web socket error. 08-02 17:27:42.377 12354 13686 I System.out: Unacceptable certificate: CN=R3, O=Let's Encrypt, C=US In the app playback settings there is an option to allow untrusted certs in playback. Please try turning that on. 1
ChaoOos 2 Posted August 2, 2022 Author Posted August 2, 2022 53 minutes ago, ebr said: Hi. I believe this is your issue: 08-02 17:27:42.377 12354 13686 I System.out: Web socket error. 08-02 17:27:42.377 12354 13686 I System.out: Unacceptable certificate: CN=R3, O=Let's Encrypt, C=US In the app playback settings there is an option to allow untrusted certs in playback. Please try turning that on. No it isn't working. But i get faster an error
ebr 16337 Posted August 2, 2022 Posted August 2, 2022 What error exactly? Can you repeat sending the log?
ChaoOos 2 Posted August 2, 2022 Author Posted August 2, 2022 1 hour ago, ebr said: What error exactly? Can you repeat sending the log? Error: To many Errors Giving up new Log Time: 14:30
ebr 16337 Posted August 2, 2022 Posted August 2, 2022 Hi. Same problem. It appears you did not change the option I suggested. 08-02 21:29:00.579 19572 19572 E EventLogger: Caused by: javax.net.ssl.SSLHandshakeException: Unacceptable certificate: CN=R3, O=Let's Encrypt, C=US ... "pref_allow_untrusted_playback":false
ChaoOos 2 Posted August 3, 2022 Author Posted August 3, 2022 On 8/2/2022 at 11:01 PM, ebr said: Hi. Same problem. It appears you did not change the option I suggested. 08-02 21:29:00.579 19572 19572 E EventLogger: Caused by: javax.net.ssl.SSLHandshakeException: Unacceptable certificate: CN=R3, O=Let's Encrypt, C=US ... "pref_allow_untrusted_playback":false New Log Time: 13:44 the box was unchecked before.
Luke 42245 Posted August 4, 2022 Posted August 4, 2022 HI, can you try sideloading our standard android app on the same device and let us know how it compares? https://emby.media/emby-for-android.html Thanks.
ebr 16337 Posted August 4, 2022 Posted August 4, 2022 17 hours ago, ChaoOos said: New Log Time: 13:44 I cannot find this log. What happened during it and what user was logged in?
ChaoOos 2 Posted August 4, 2022 Author Posted August 4, 2022 12 minutes ago, ebr said: I cannot find this log. What happened during it and what user was logged in? The time you sent the log (in Eastern Time please - UTC -5) 13:43 (20:43 in Germany) The name of the Emby user on the local server that was logged in at the time OdoundBritta
ebr 16337 Posted August 4, 2022 Posted August 4, 2022 Thanks I found it now. It is still a certificate problem. Are you sure it is valid? If you use plain http, does it work?
ChaoOos 2 Posted August 6, 2022 Author Posted August 6, 2022 On 8/4/2022 at 4:39 PM, ebr said: Thanks I found it now. It is still a certificate problem. Are you sure it is valid? If you use plain http, does it work? It doesnt work with http either. The time you sent the log (in Eastern Time please - UTC -5) 02:31 (09:31 in Germany) The name of the Emby user on the local server that was logged in at the time Odo
ChaoOos 2 Posted August 6, 2022 Author Posted August 6, 2022 On 8/4/2022 at 4:14 AM, Luke said: HI, can you try sideloading our standard android app on the same device and let us know how it compares? https://emby.media/emby-for-android.html Thanks. in 2 days i can test it personally.
ebr 16337 Posted August 6, 2022 Posted August 6, 2022 Hi. Now it is just timing out. 08-06 09:31:34.270 15952 15952 E EventLogger: Caused by: java.net.SocketTimeoutException: timeout Is this on a very slow connection? If you lower the in app quality setting, does it help?
ChaoOos 2 Posted August 6, 2022 Author Posted August 6, 2022 3 hours ago, ebr said: Hi. Now it is just timing out. 08-06 09:31:34.270 15952 15952 E EventLogger: Caused by: java.net.SocketTimeoutException: timeout Is this on a very slow connection? If you lower the in app quality setting, does it help? no its fiber 100k. i tested another movie before and its working The time you sent the log (in Eastern Time please - UTC -5) 12:18 (19:18 in Germany) The name of the Emby user on the local server that was logged in at the time Odo
