noah727 1 Posted August 1, 2022 Posted August 1, 2022 Hi, Just installed Emby today to my desktop PC (version 4.7.5.0) and to my LG TV (75NANO80TPA). I have installed libraries, and no issue playing movies and video files on the TV. But TV can't display or show photos and images. Folders containing them says no files found. Is there anything I'm missing here? I already checked the settings and I can't see anything pertaining to photos or images. Only for audio and video. Would appreciate your advise. Thanks in advance.
Luke 42237 Posted August 1, 2022 Posted August 1, 2022 Hi, are you using the Emby LG app, or just LG Dlna?
noah727 1 Posted August 1, 2022 Author Posted August 1, 2022 7 minutes ago, Luke said: Hi, are you using the Emby LG app, or just LG Dlna? Hi Luke, am using Emby LG app directly from LG App Store (WebOS).
Luke 42237 Posted August 1, 2022 Posted August 1, 2022 @noah727 please attach the emby server log from when you tried to view photos in the Emby LG app: Thanks !
noah727 1 Posted August 2, 2022 Author Posted August 2, 2022 On 8/1/2022 at 9:46 AM, Luke said: @noah727 please attach the emby server log from when you tried to view photos in the Emby LG app: Thanks ! I'm not exactly techy, but perhaps given some guidance on steps how to do that, I can try and do as instructed. Thanks again. @cayars
Carlo 4561 Posted August 4, 2022 Posted August 4, 2022 On 8/2/2022 at 2:45 AM, noah727 said: I'm not exactly techy, but perhaps given some guidance on steps how to do that, I can try and do as instructed. Thanks again. @cayars There's instructions inside the post Luke gave you that tell you where to get the server logs. See if that helps and if not let us know.
noah727 1 Posted August 5, 2022 Author Posted August 5, 2022 23 hours ago, cayars said: There's instructions inside the post Luke gave you that tell you where to get the server logs. See if that helps and if not let us know. Yes, I can see it now. Sorry for missing it. Will revert once I am able to collect the logs. Thanks again. 1
noah727 1 Posted August 5, 2022 Author Posted August 5, 2022 Logs attached now. embyserver-63795131393.txt hardware_detection-63795131413.txt
Luke 42237 Posted August 5, 2022 Posted August 5, 2022 Hi, how have you configured your emby libraries? Also, you're saying the issue is in the Emby LG app, but how does it compare if you browse from the web interface of the server machine?
