Luke 42287 Posted November 20, 2022 Posted November 20, 2022 On 11/19/2022 at 6:04 AM, KrakaClue said: Hi Emby team, I have a similar problem with Nvidia Shield and Emby android TV app. The error is: Impossible to convert between the formats supported by the filter 'hwupload@f4' and the filter 'auto_scale_0' I tested Emby versions: previous release (no problem) -> I don't have log to attach 4.7.8 (attached files ending with __478) 4.7.9 (attached files ending with __479) Same problem on both releases. I cannot test the beta release but I hope it will fix this problem. embyserver__479.txt 120.76 kB · 0 downloads ffmpeg-transcode-f4bbc236-30de-4f82-9895-6156cb253f96_1__479.txt 28.9 kB · 0 downloads embyserver__478.txt 706.56 kB · 0 downloads ffmpeg-transcode-a9e3976b-11d2-4d1e-a235-5311270ec0a3_1__478.txt 43.28 kB · 0 downloads Hi, yes this should be resolved in the upcoming 4.8 server release. 1
Quadrubo 8 Posted January 8, 2023 Posted January 8, 2023 Also had this exact error, can confirm the beta build fixes this for now. 1
Touz604 11 Posted May 26, 2023 Author Posted May 26, 2023 Well upon the discovery of the vulnerability, I decided to spin up a Beta instance of Emby, version 4.8.0.37. I tried transcoding a movie and HW transcoding failed. It only works with 1 subtitles, out of 4. When selecting the other ones, it crashes, even when selecting no subtitles. I tried a different movie and for this one, all subtitles made playback crash, except when selecting no subtitles. Here are some logs of the crashed playback and working playback of the same file, on the same Emby server version. ffmpeg-transcode-48487de0-a28e-4c65-99ac-eaf48c18e8e0_1_working.txt embyserver_working.txt ffmpeg-transcode-5a858691-f286-48dd-a253-d4320e334d0a_1_crash.txt embyserver_crash.txt
Solution Luke 42287 Posted August 10, 2023 Solution Posted August 10, 2023 Hi, please try the latest 4.8 build and let us know how that compares. Thanks !
Touz604 11 Posted September 15, 2023 Author Posted September 15, 2023 I tested 2 movies on 4.8.0.46 and they both seem to work. Thank you so much! 1
