Waldoo 14 Posted July 30, 2022 Posted July 30, 2022 whats going on here? Using a synology docker version. embyserver(1).txt
Luke 42243 Posted July 30, 2022 Posted July 30, 2022 Hi, try turning off intro detection, then removing the theme song plugins, restarting the server and seeing how that compares. Thanks.
Patricksp 2 Posted July 30, 2022 Posted July 30, 2022 (edited) I don't know if it's the same problem I had. I had a bad file from my last upload of a movie that was causing it to stop searching. I deleted the file that didn't look right and it started working again. It was trial and error to find the bad file. I hope this helps Edited July 30, 2022 by Patricksp
Solution Waldoo 14 Posted July 31, 2022 Author Solution Posted July 31, 2022 (edited) That worked thnx @Luke Edited July 31, 2022 by Waldoo 1
