ab123ga 18 Posted October 3, 2014 Posted October 3, 2014 I have a question about the new cinema mode. I have done the setup as noted in the announcement however when I play a movie it just plays the movie. The web client user setting says it is on. Am I missing something? Log file below. https://app.box.com/...b4et366eguzaui7
speechles 2060 Posted October 3, 2014 Posted October 3, 2014 There is a bit more to it than just tell it the user prefences and choosing cinema mode... You need to use the web client dashboard administration page. Choose playback and the cinema mode tab as above. There are two plugins that make this happen: Local trailers and channel trailers. You can install both, or only one of them. There are options to control this behavior for each plugin listed. Sent from my Nexus 7 using Tapatalk
Luke 42184 Posted October 3, 2014 Posted October 3, 2014 you don't necessarily need the local trailer plugin. you can also set your own trailers up manually.
ab123ga 18 Posted October 4, 2014 Author Posted October 4, 2014 I installed the trailers plugin and it worked. The instructions was a bit lacking b/c I see no where they they specifically said you must install the plugin for this new feature to work. Unless I missed something. Thanks for the review.
bLaZeR666_uk 1 Posted October 4, 2014 Posted October 4, 2014 Hi Guys Been using Media Browser for nearly a year now, I have paid for the lifetime supporter membership. I have the internet trailers selected but when playing a movie there are no trailers played. I can play a custom file before viewing a movie but not the trailers. Have I missed something obvious? as I cant figure out whats wrong. TIA
bluemonkey07 590 Posted October 4, 2014 Posted October 4, 2014 Have you installed the trailers plugin?
ab123ga 18 Posted October 4, 2014 Author Posted October 4, 2014 My bad. I reread and it did note plugin required.
Luke 42184 Posted October 4, 2014 Posted October 4, 2014 Read the help text on the cinema mode configuration page
bLaZeR666_uk 1 Posted October 4, 2014 Posted October 4, 2014 Have you installed the trailers plugin? Yes Some trailers have downloaded but only partially so the trailers are incomplete.
bLaZeR666_uk 1 Posted October 7, 2014 Posted October 7, 2014 Still no further along with this. I have got the trailer plugin working but the new built in cinema mode doesn't work at all. TIA
bLaZeR666_uk 1 Posted October 7, 2014 Posted October 7, 2014 Ok Internet trailers are now working after I disabled it, re-installed media server. Trailers now play before my main movie but...there is no sound.... Any ideas?
ebr 16306 Posted October 7, 2014 Posted October 7, 2014 We'll need more information to be able to help: How to Report a Problem
bluemonkey07 590 Posted October 8, 2014 Posted October 8, 2014 (edited) Ok Internet trailers are now working after I disabled it, re-installed media server. Trailers now play before my main movie but...there is no sound.... Any ideas? Are you using MBT as the client? There seems to be a few people with this issue in MBT see here http://mediabrowser.tv/community/index.php?/topic/10819-Streaming-trailers-not-working Edited October 7, 2014 by Vidman 1
