Luke 42241 Posted October 8, 2022 Posted October 8, 2022 @DRW19 what platform are you running Emby Server on? There is no other reported issue of this. The one you mentioned is only related to the search function in Emby Server. Have you updated to Emby Server 4.7.8? Are you still seeing an issue with that?
DRW19 2 Posted October 8, 2022 Author Posted October 8, 2022 I use 4.7.4.0. I have converted all files now to US Apostrophe 0x27. I think with Acute Accent it just doesn't work. Thanks a lot for the support. This has settled the issue for me. 1
Luke 42241 Posted October 9, 2022 Posted October 9, 2022 How did you change them? Just in the file names, or embedded metadata, or both?
