Chromecast volume always 100%
PCSoftware
Hi all,
I recently started using Emby, and so far I'm really satisfied with the experience, except for one issue. When I cast to my Chromecast speaker from the web application, the volume indicator always says it's playing at 100% (even though that's not the case). When I adjust the volume using the indicator, it changes correctly, it just doesn't display the right percentage at the start, which makes it hard to adjust the volume the right way. Is this a bug or can I configure this somewhere?
