CAPRICORNX10X 68 Posted July 29, 2022 Posted July 29, 2022 Hello, I would be happy to help emby misidentifies the movie X-men: First Class At first he identifies it as a documentary film: X-Men: First Class 35mm Special (2011), ID number in tmdb - 691677 Even after I change the movie identification in both tmdb and imdb He still doesn't recognize the film correctly!
pwhodges 2025 Posted July 29, 2022 Posted July 29, 2022 Have you just changed the values in the metadata, or have you actually gone through the identify procedure using the correct id? My practice in this kind of situation is simply to add [tmdbid=49538] to the folder name; the change forces Emby to re-identify it, and the value overrides the previous error (the value I've given is the one you need in this case) - it also ensures that the identification remains correct if a full rescan is required for any reason. Paul
CAPRICORNX10X 68 Posted July 29, 2022 Author Posted July 29, 2022 excellent I will try it now. With this method that changes the name of the folder, Does it just force emby to take that info? Can I do this with all movies? Right...
CAPRICORNX10X 68 Posted July 29, 2022 Author Posted July 29, 2022 9 minutes ago, pwhodges said: simply to add [tmdbid=49538] to the folder name Tried changing the folder name as you suggested didn't help. Where exactly do I add it? At the end at the beginning?
pwhodges 2025 Posted July 29, 2022 Posted July 29, 2022 At the end (and with the brackets). I don't know why it wouldn't work - I do this regularly with tricky items (though only two of my hundreds of mainstream movies need it), and it never fails for me. My main use of it is for operas, which I wish to name in the filing system differently from how the metadata providers name them. What is your folder structure? I use the recommended format of a folder under the library folder for each movie separately, and no further nesting (such as grouping folder for a series - these get joined as collections in Emby, but not in the file system). Paul
CAPRICORNX10X 68 Posted July 29, 2022 Author Posted July 29, 2022 1 minute ago, Luke said: What was the solution? Add to folder [tmdbid=49538] - "At the end (and with the brackets)"
Luke 42186 Posted August 5, 2022 Posted August 5, 2022 I think you have the folder/file named wrong because look: https://www.themoviedb.org/movie/691677-x-men-first-class-35mm-special?language=en-US I think Emby Server acted correctly in the beginning.
CAPRICORNX10X 68 Posted August 5, 2022 Author Posted August 5, 2022 no luke, You are wrong. this is not the movie. my folder name is : x-men first class (2011) - So emby should automatically recognize the movie as X-Men: First Class (2011) — The Movie Database (TMDB) (themoviedb.org) And not the identification you brought
Luke 42186 Posted August 5, 2022 Posted August 5, 2022 OK I think this needs to be reported to MovieDb because when you search, look at what is the first result back: https://www.themoviedb.org/search?query=X-Men%3A+First+Class Maybe @Happy2Play can report that to them.
CAPRICORNX10X 68 Posted August 5, 2022 Author Posted August 5, 2022 True, I noticed that too. In the search, a documentary film appears first
CAPRICORNX10X 68 Posted August 5, 2022 Author Posted August 5, 2022 5 minutes ago, Luke said: Maybe @Happy2Play can report that to them. I also reported. From what I've seen there are more reports about it. Look at the answer they gave
Luke 42186 Posted August 5, 2022 Posted August 5, 2022 Try responding with this: The issue is actually more basic and has nothing to do with documentary/movie/series classification. If you search for "X-Men: First Class", there is an exact title match in the search results, but this is the second result in the list. For example: https://www.themoviedb.org/search?query=X-Men%3A+First+Class Instead, "X-Men: First Class 35mm Special" gets chosen as the best match. Applications can workaround this, but such workarounds can sometimes have negative effects. Ideally their search engine would be smart enough to order the results based on how closely they match the search criteria.
CAPRICORNX10X 68 Posted August 19, 2022 Author Posted August 19, 2022 On 8/5/2022 at 10:20 PM, Luke said: Try responding with this: The issue is actually more basic and has nothing to do with documentary/movie/series classification. If you search for "X-Men: First Class", there is an exact title match in the search results, but this is the second result in the list. For example: https://www.themoviedb.org/search?query=X-Men%3A+First+Class Instead, "X-Men: First Class 35mm Special" gets chosen as the best match. Applications can workaround this, but such workarounds can sometimes have negative effects. Ideally their search engine would be smart enough to order the results based on how closely they match the search criteria. Okay, This is the answer from tmdb support They say the problem is here with emby
rbjtech 5335 Posted August 19, 2022 Posted August 19, 2022 24 minutes ago, CAPRICORNX10X said: Okay, This is the answer from tmdb support They say the problem is here with emby Then they are wrong .. lol As Luke explained above - if you query 'X-Men: First Class' - you don't get back that as the 1st result. It should an EXACT match - why is it not ? I'm not sure how TMDB think this is not their problem - it is. If you try 'X-Men: F' - you get X-Men: Days of Future Past as the first entry ! ?? Please ask them to explain the logic here and maybe Emby can accommodate.
CAPRICORNX10X 68 Posted August 19, 2022 Author Posted August 19, 2022 5 minutes ago, rbjtech said: Then they are wrong .. lol As Luke explained above - if you query 'X-Men: First Class' - you don't get back that as the 1st result. It should an EXACT match - why is it not ? I'm not sure how TMDB think this is not their problem - it is. If you try 'X-Men: F' - you get X-Men: Days of Future Past as the first entry ! ?? Please ask them to explain the logic here and maybe Emby can accommodate. is send again you and luke comment
Luke 42186 Posted August 19, 2022 Posted August 19, 2022 Try responding with exactly what I said above copy and paste @Happy2Play
CAPRICORNX10X 68 Posted August 19, 2022 Author Posted August 19, 2022 1 hour ago, Luke said: Try responding with exactly what I said above copy and paste @Happy2Play ok 1
Happy2Play 9800 Posted August 26, 2022 Posted August 26, 2022 The Mods over there don't see it as a problem as TMDB does not have an exact search function. But technically the discussion in that item is not the correct area as there is not issue with this item itself. Reported Problem for X-Men: First Class 35mm Special - Discuss X-Men: First Class 35mm Special — The Movie Database (TMDB) (themoviedb.org) New topic Search results priorities - Talk — The Movie Database (TMDB) (themoviedb.org)
Happy2Play 9800 Posted August 26, 2022 Posted August 26, 2022 7 minutes ago, Luke said: Looks like it's on their to do list, no? Per the response it would apear so.
rbjtech 5335 Posted August 26, 2022 Posted August 26, 2022 (edited) 5 hours ago, Happy2Play said: The Mods over there don't see it as a problem as TMDB does not have an exact search function. But technically the discussion in that item is not the correct area as there is not issue with this item itself. Reported Problem for X-Men: First Class 35mm Special - Discuss X-Men: First Class 35mm Special — The Movie Database (TMDB) (themoviedb.org) New topic Search results priorities - Talk — The Movie Database (TMDB) (themoviedb.org) lol - this is sorta fundamental to a metadata database no ? "let me search for accurate metadata and get a load of irrelevant junk back, but the answer you want is likely in there somewhere - you sort it out.." Edited August 26, 2022 by rbjtech 1
Luke 42186 Posted August 26, 2022 Posted August 26, 2022 Even if they don't care about what comes out of the API, you'd think they'd want their search page to produce the best results as possible.
CAPRICORNX10X 68 Posted August 26, 2022 Author Posted August 26, 2022 1 minute ago, Luke said: Even if they don't care about what comes out of the API, you'd think they'd want their search page to produce the best results as possible. very true
