DragonSkills99 4 Posted June 1, 2023 Posted June 1, 2023 4 hours ago, Luke said: @DragonSkills99what version of android does this device run? @Luke I'm currently running on Android 13 using a Samsung Galaxy Z4 Fold.
Luke 42243 Posted June 28, 2023 Posted June 28, 2023 Can you provide a sample video for testing? Thanks.
DragonSkills99 4 Posted July 20, 2023 Posted July 20, 2023 On 6/28/2023 at 9:19 AM, Luke said: Can you provide a sample video for testing? Thanks. Hi @Luke, sorry for the late reply, but I can't provide a sample video as all my videos are private copies and it would be against the law sharing it. But interestingly it seems to work now, I just don't know if updating to the latest beta or upgrade the RAM from 4GB to 20GB did the trick. But 4 GB definitely did cause some problems with emby on the NAS like Emby being and loading slowly. I tested it with both, my external screen through a thunderbolt 4 docking station and directly on my NReal Air Glasses only using a cable and both worked just fine now. All in all the problem is now solved for me. Kind regards DragonSkills99 1
