dieffe70 9 Posted July 28, 2022 Posted July 28, 2022 (edited) Hi there, Emby server free on a 253d Qnap with 8gb ram. All work good... but I'm having issues with 4K hevc videos 10bit. Testing on local network pc browser it take very long to load an then streaming is very laggy and freezed and most of the time basically don't work. On android app it don't start at all (I can reproduce Hevc file).. I get slightly better result lowering streaming resolution.. but anyway after a bit Qnap goes full CPU and RAM. My question is: should I forget to play such kind of file actually or there's something I can do? PAid subscription and transcode function could be a solution? or simply I don't have enough hardware spec to do this? thanks Edited July 28, 2022 by dieffe70
Luke 42239 Posted July 28, 2022 Posted July 28, 2022 @dieffe70 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
dieffe70 9 Posted July 28, 2022 Author Posted July 28, 2022 This is what I get.. but I think I can't simply play those H265 file guess.. it's may be HW limitation or need a pay subscription ------------------------- Enable Playback Remuxing: True Enable Video Playback Transcoding: True Enable Audio Playback Transcoding: True >>>>>> Hardware Decoders for hevc [X] VAAPI GeminiLake UHD Graphics 600 - H.265 (HEVC) [X] QuickSync GeminiLake UHD Graphics 600 - H.265 (HEVC) >>>>>> Hardware Encoders for h264 [X] VAAPI GeminiLake UHD Graphics 600 - H.264 (AVC) [X] QuickSync GeminiLake UHD Graphics 600 - H.264 (AVC) >>>>>> Selected Codecs Decoder Automatic software decoder Encoder x264 Software Encoder Max Bitrate: 781 Mbit/s Color Formats: YUV420P, YUVJ420P, YUV422P, YUVJ422P, YUV444P, YUVJ444P, NV12, NV16, NV21, YUV420P10, YUV422P10, YUV444P10, NV20, GRAY8, GRAY10 - Bit Depths: 8, 10, 12, 14 Profiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 10 Profile (Level 6.2), High 4:2:2 Profile (Level 6.2), High 4:4:4 Predictive Profile (Level 6.2) >>>>>> FindVideoEncoder - MediaType: h264, UseHardwareCodecs: True, HWA-Mode: Automatic Warning: Hardware acceleration is not available as it requires a valid Premiere Subscription Info Checking: 'x264 Software Encoder' Info Check successful - selecting 'x264 Software Encoder' >>>>>> FindVideoDecoder - MediaType: hevc, UseHardwareCodecs: True, HWA-Mode: Automatic Warning: Hardware acceleration is not available as it requires a valid Premiere Subscription Info Checking: 'Automatic software decoder' Info Check successful - selecting 'Automatic software decoder' Info Tone Mapping would be desired, but software tone mapping is disabled Info Check successful - selecting 'Automatic software decoder' Info Tone Mapping would be desired, but software tone mapping is disabled >>>>>> Processing Plan Name CanDoInHW WillDoInHW Reason Automatic software decoder >> False False Software Codec VideoInput >> False False Not a hardware decoder ToneMapping (when possible) >> False False VideoOutput >> False False Not a hardware encoder x264 Software Encoder >> False False Software Codec >>>>>> Video Processing Steps for [0:0]: H.265 (HEVC) Step HW-Context Format SW-Format Size Next HEVC >> - yuv420p10 yuv420p10 3840x2160 >> format format >> - yuv420p yuv420p 3840x2160 >> 12:45:38.337 ffmpeg version 5.0.0-emby_2022_05_07 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC 12:45:38.337 built with gcc 8.3.0 (crosstool-NG 1.24.0) 12:45:38.337 Execution Date: 2022-07-28 12:45:38 12:45:38.356 [matroska,webm @ 0x1b9ff40] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options 12:45:38.357 [matroska,webm @ 0x1b9ff40] Could not find codec parameters for stream 5 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options 12:45:38.358 [matroska,webm @ 0x1b9ff40] Could not find codec parameters for stream 6 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options 12:45:38.366 Input #0, matroska,webm, from '/share/Archivio/Media/Serie/Trono-di-spade/Game.of.Thrones.S02E01.Il.Nord.Non.Dimentica.ITA.ENG.2160p.HDR.BluRay.x265-MeM.mkv': 12:45:38.367 Metadata: 12:45:38.368 encoder : libebml v1.3.0 + libmatroska v1.4.1 12:45:38.369 creation_time : 2020-11-11T17:10:04.000000Z 12:45:38.370 Duration: 00:52:44.22, start: 0.000000, bitrate: 17143 kb/s 12:45:38.372 Stream #0:0(eng): Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], Level 153, 23.98 fps, 23.98 tbr, 1k tbn (default) 12:45:38.375 Metadata:
GrimReaper 4895 Posted July 28, 2022 Posted July 28, 2022 8 hours ago, dieffe70 said: PAid subscription and transcode function could be a solution? Yes. HW acceleration requires Premiere subscription. Your 253d has QS-enabled quad-core Celeron J4125 (UHD 600) which, while not a beast, is a decent CPU that should have no issues with few HEVC transcodes, but not in software only. You might subscribe for a month (roughly 5 bucks) and see how does it work for you with HW transcoding. (btw it is always advisable to post full logs, not snippets, as they would usually tell more relevant data). 1
dieffe70 9 Posted July 29, 2022 Author Posted July 29, 2022 Thank you very much. I'll do a test soon.
Luke 42239 Posted August 1, 2022 Posted August 1, 2022 @dieffe70 let us know how you get on. Thanks ! 1
