resonator79 0 Posted July 28, 2022 Posted July 28, 2022 Basically, overnight all users stopped working. (I was experimenting with reverse proxy / cloudflare yesterday and had a subdomain exposed; maybe incompetence, maybe an attack, another issue though) When I go through the password reset procedure, I get to creating the file with the pin, I open up the link on my local network, the webserver states that "all password for the following users have been reset", but when I go ahead and enter my username and no password manually, I get "invalid username or password" again. Can I reset the user.db or go back to defaults without loosing my library? What can I do?
resonator79 0 Posted July 28, 2022 Author Posted July 28, 2022 Fixed it myself by doing this: 1) Edited the users.db table where the default user is stored to a blank password. 2) Deleted data/auth* 3) Restarted container That worked.
Luke 42245 Posted July 28, 2022 Posted July 28, 2022 9 hours ago, resonator79 said: Basically, overnight all users stopped working. (I was experimenting with reverse proxy / cloudflare yesterday and had a subdomain exposed; maybe incompetence, maybe an attack, another issue though) When I go through the password reset procedure, I get to creating the file with the pin, I open up the link on my local network, the webserver states that "all password for the following users have been reset", but when I go ahead and enter my username and no password manually, I get "invalid username or password" again. Can I reset the user.db or go back to defaults without loosing my library? What can I do? Hi, are you sure you entered the correct username when you tried this? @Happy2Play are you able to reproduce?
resonator79 0 Posted July 28, 2022 Author Posted July 28, 2022 I promise you I used the exact username.
Luke 42245 Posted July 28, 2022 Posted July 28, 2022 12 minutes ago, resonator79 said: I promise you I used the exact username. Same as what exactly?
