AMMINISTRATORE 9 Posted July 27, 2022 Posted July 27, 2022 Hi, I apologize, but I am using a translator, I hope it correctly translates my problem that I am going to describe: I would like to order the contents of a dvd that I have converted into mp4, but I would like to make the various contents appear from the drop-down menu with an order chosen by me, for example: 1-the film-2: making of 3: special contents ... .etc. etc. I tried to rename every single file to A-B-C-D .... or even 01-02-03-04 ... but every time I don't get the chronological sequence I expected. is there a chance to solve this problem? Thank you
Abobader 3485 Posted July 27, 2022 Posted July 27, 2022 Hello AMMINISTRATORE, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
ebr 16307 Posted July 27, 2022 Posted July 27, 2022 Hi. You'll want to add those other items as specials instead. Then they will appear as icons on the detail screen. Movie Naming
pwhodges 2025 Posted July 27, 2022 Posted July 27, 2022 (edited) The dropdown is intended and designed for different qualities of the same file. The default is chosen as the "best" for any given client and situation; you cannot choose either the order of the options or the default option. In any case, the way ebr has pointed out gives a far superior experience for what you are aiming to do. Paul Edited July 27, 2022 by pwhodges
AMMINISTRATORE 9 Posted July 27, 2022 Author Posted July 27, 2022 (edited) GREAT!!!!...Thanks a lot Edited July 27, 2022 by AMMINISTRATORE
