DUCKPOWER13 0 Posted July 24, 2022 Posted July 24, 2022 having the same issue was working fine and when to remotely use Emby and it wasn't working butt has been fine for 4 months no issue, nothing has changed in these 4 months i have tried your port forwarding link and and you other connections help link and everting is correct
Luke 42243 Posted July 25, 2022 Posted July 25, 2022 Hi @DUCKPOWER13 I would suggest checking out our Connection Troubleshooter:; https://support.emby.media/support/solutions/articles/44001849007-connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks !
DUCKPOWER13 0 Posted July 31, 2022 Author Posted July 31, 2022 i have and I've gone through the forms on here and non of them have helped
DUCKPOWER13 0 Posted July 31, 2022 Author Posted July 31, 2022 it was working and just stopped nothing was changed
Luke 42243 Posted July 31, 2022 Posted July 31, 2022 2 hours ago, DUCKPOWER13 said: i have and I've gone through the forms on here and non of them have helped Hi, exactly which steps succeeded and which ones did not? The answer to that will help identify where the problem is. Thanks.
