foghat 65 Posted October 3, 2014 Posted October 3, 2014 (edited) Hi, I am seeing strange behavior with Cinema mode. I have the necessary plugins installed and have configured appropriately on the server. If I try playing a movie on: 1. the web interface using Chrome (desktop), everything works as expected. 2. the web interface using IE 11 (desktop), the trailers just do not play - goes straight to movie. See logs named IE.zip: 3. MBT (3.0.5362.41853), I get two trailers playing for about 1-2 seconds each. The trailers then get marked as watched on the server. See logs named mbt.zip 4. the web interface using ios Safari (iphone 5s), the trailers do not play - straight to movie. See logs named safari_ios.zip I do not have MB Intros currently installed. As a bit of an aside, I cannot even get the movie details page to load if I use Chrome in iOS. Works fine until trying to view a movie detail then hangs. No other navigation options work at this point. I know things used to work in chrome ios. See log XXXX_chrome_ios.txt Thoughts? IE.zip mbt.zip safari_ios.zip server-63547945087_iOS_chrome.txt Edited October 3, 2014 by foghat
Luke 42184 Posted October 4, 2014 Posted October 4, 2014 well for #4 the blog was very clear. desktop browsers only. and they're not supported in IE. I forgot to mention that.
foghat 65 Posted October 4, 2014 Author Posted October 4, 2014 well for #4 the blog was very clear. desktop browsers only. and they're not supported in IE. I forgot to mention that. Fair enough. I did not see the blog entry. Point 3 is the big one for me.
