all4dom 101 Posted July 23, 2022 Posted July 23, 2022 The emby guide is not displaying my default channel lineup. I have it selected in channels but there is nothing to click on in guide.
Luke 42241 Posted July 24, 2022 Posted July 24, 2022 Hi there, can you please describe your issue in more detail? Thanks.
all4dom 101 Posted July 24, 2022 Author Posted July 24, 2022 I customized my channels for live TV. I.have default line up selected & my customized channel line up appears correctly in fire tv & roku, but not in the apple TV.
Luke 42241 Posted July 24, 2022 Posted July 24, 2022 Can you please show us a specific example? What do you see? What do you expect to see?
all4dom 101 Posted July 25, 2022 Author Posted July 25, 2022 Not sure how to show an example. I edited my channel line in the server. My roku & fire tv display that edited.channel line up, but on the Apple TV it does not.
Luke 42241 Posted July 25, 2022 Posted July 25, 2022 Comparison screenshots, along with some discussion of the two so that we can visualize what's happening would be helpful. Thanks.
all4dom 101 Posted July 26, 2022 Author Posted July 26, 2022 Ok @Luke The Emby server Live TV Guide shows my channel line up that I edited. As long as I select default channel line up on my streaming devices, my live tv guide should reflect my channel line up from the server. It does on fire tv & roku,, but not apple tv. On the apple tv guide pg 1 & 2 pic, it shows my channel line up on the apple tv, but its not in the order that I created on the server. The apple tv channels pic shows how I selected default channel line up, but its not working on apple tv. Also, it was a good while back, but you & ebr or it was ebr that told me how to do this. I believe something along the way of one of the server updates may have caused this because I had to re edit my whole channel line up.
all4dom 101 Posted July 28, 2022 Author Posted July 28, 2022 @luke any update. I'm hoping the guide issue is a simple fix.
Luke 42241 Posted July 28, 2022 Posted July 28, 2022 Please try again with the next update to the app. Thanks.
