roaku 842 Posted July 6, 2022 Posted July 6, 2022 9 minutes ago, CAPRICORNX10X said: Luka what if make an option instead of a background when going into the details of the film. It will be possible to put a background with sound (video clip with sound) like in blu-ray titles You can already do this with videos and music: https://support.emby.media/support/solutions/articles/44001159179-theme-songs-videos
CAPRICORNX10X 68 Posted July 6, 2022 Author Posted July 6, 2022 I got. And I have already created..thank you very much Is there a way to make audio and video repeat itself every time the segment ends?
Luke 42245 Posted July 13, 2022 Posted July 13, 2022 Quote 1.Regarding the implementation of a right-to-left display, I saw that it is in the emby theater in windows. Although not in full but at least it is. Will there be such a change in the rest of the platforms? Android, LG, Samsung and more ...? Hi, yes we'll get this to as many apps as is possible.
CAPRICORNX10X 68 Posted July 23, 2022 Author Posted July 23, 2022 Hi Luke, First of all, thanks again for the implementation of a right-to-left display. But there are many other things that need to be changed on the right-to-left display as well Another thing is that there are some incorrect translations in the Hebrew language. Is it possible to fix them?
ebr 16337 Posted July 23, 2022 Posted July 23, 2022 Hi. I merged your topics. No need for two of them. Thanks.
CAPRICORNX10X 68 Posted July 23, 2022 Author Posted July 23, 2022 18 minutes ago, ebr said: Hi. I merged your topics. No need for two of them. Thanks. ok
Luke 42245 Posted July 23, 2022 Posted July 23, 2022 4 hours ago, CAPRICORNX10X said: Another thing is that there are some incorrect translations in the Hebrew language. I don't think that's for me to look at. That's something for the translators on OneSky. You can always jump in and help translate.
CAPRICORNX10X 68 Posted July 23, 2022 Author Posted July 23, 2022 3 hours ago, Luke said: I don't think that's for me to look at. That's something for the translators on OneSky. You can always jump in and help translate. ok i will look into it. What about the other things in the display from right to left?
Luke 42245 Posted July 24, 2022 Posted July 24, 2022 5 hours ago, CAPRICORNX10X said: ok i will look into it. What about the other things in the display from right to left? Such as?
CAPRICORNX10X 68 Posted July 24, 2022 Author Posted July 24, 2022 just for example, Most of the buttons/icons need adjustments Like let's say the play symbol ... I also attach an example from a picture There are many more that need adjustments
Luke 42245 Posted July 24, 2022 Posted July 24, 2022 4 hours ago, CAPRICORNX10X said: just for example, Most of the buttons/icons need adjustments Like let's say the play symbol ... I also attach an example from a picture There are many more that need adjustments Yes the icons will be flipped now for the next set of app updates. Thanks.
CAPRICORNX10X 68 Posted July 24, 2022 Author Posted July 24, 2022 Hi, thanks Luke Is it possible to update the right-to-left display in the LG webos version as well?
Luke 42245 Posted July 24, 2022 Posted July 24, 2022 13 minutes ago, CAPRICORNX10X said: Hi, thanks Luke Is it possible to update the right-to-left display in the LG webos version as well? HI, it will be in the next LG app update as well, but what LG model do you have? The way we're doing this is not going to work on devices with older rendering engines.
CAPRICORNX10X 68 Posted July 24, 2022 Author Posted July 24, 2022 1 minute ago, Luke said: HI, it will be in the next LG app update as well, but what LG model do you have? The way we're doing this is not going to work on devices with older rendering engines. lg oled c1 65
Luke 42245 Posted July 24, 2022 Posted July 24, 2022 4 minutes ago, CAPRICORNX10X said: lg oled c1 65 OK that sounds on the newer side so you should be fine.
CAPRICORNX10X 68 Posted July 24, 2022 Author Posted July 24, 2022 6 minutes ago, Luke said: OK that sounds on the newer side so you should be fine. Happy news
CAPRICORNX10X 68 Posted July 28, 2022 Author Posted July 28, 2022 On 7/24/2022 at 11:32 PM, Luke said: HI, it will be in the next LG app update as well, but what LG model do you have? The way we're doing this is not going to work on devices with older rendering engines. Implementing a right-to-left display in other apps, please luke We need to implement what you done in other applications, very important android tv and lg webos There are thousands of users waiting for this update 1
Luke 42245 Posted July 28, 2022 Posted July 28, 2022 Make sure to tell all your right to left friends that this will be coming. Thanks.
CAPRICORNX10X 68 Posted July 28, 2022 Author Posted July 28, 2022 2 minutes ago, Luke said: Make sure to tell all your right to left friends that this will be coming. Thanks. Are you a little cynical about me? And everyone is waiting for an update on Android TV Thank you very much Luke really appreciates your work You really are the best media server
ebr 16337 Posted July 28, 2022 Posted July 28, 2022 5 hours ago, CAPRICORNX10X said: And everyone is waiting for an update on Android TV Hi. As I mentioned in the other thread, you should use the standard Android app on your TV device and then you will have full RTL support.
CAPRICORNX10X 68 Posted July 28, 2022 Author Posted July 28, 2022 Is there a difference in the emby interface between android tv and standart android ? I'm asking because I really liked the interface and features in Emby Android TV
CAPRICORNX10X 68 Posted August 6, 2022 Author Posted August 6, 2022 On 7/28/2022 at 7:05 PM, Luke said: Make sure to tell all your right to left friends that this will be coming. Thanks. Is there an estimate of when the changes will be? display View from right to left on android tv and lg webos
Luke 42245 Posted August 6, 2022 Posted August 6, 2022 Hi, in the next update to the emby LG app. Thanks.
CAPRICORNX10X 68 Posted August 6, 2022 Author Posted August 6, 2022 4 minutes ago, Luke said: Hi, in the next update to the emby LG app. Thanks. Okay, so My question *when* remains open thank you luke
