CAPRICORNX10X 68 Posted June 21, 2022 Posted June 21, 2022 Please support right-to-left text display To be compatible with the Hebrew language. I know thousands of people who use emby and are really desperate for this support. 1
Luke 42244 Posted June 21, 2022 Posted June 21, 2022 Hi there, yes it's something we should support. Thanks.
CAPRICORNX10X 68 Posted June 22, 2022 Author Posted June 22, 2022 (edited) Okay , Thank you If you want, I can help with this on a full volunteer. In everything related to full support for the Hebrew language, I would be happy. And where can I come up with more improvements and suggestions? Edited June 22, 2022 by CAPRICORNX10X
Luke 42244 Posted June 22, 2022 Posted June 22, 2022 14 minutes ago, CAPRICORNX10X said: And where can I come up with more improvements and suggestions? Hi, you can continue to create more feature request topics. Thanks !
CAPRICORNX10X 68 Posted June 22, 2022 Author Posted June 22, 2022 21 hours ago, Luke said: Hi there, yes it's something we should support. Thanks. Will there be any intention to support this, in future versions of emby?
CAPRICORNX10X 68 Posted June 30, 2022 Author Posted June 30, 2022 any timeline for the request? this is very important ...
Luke 42244 Posted June 30, 2022 Posted June 30, 2022 HI, I don't have a timeline, but maybe instead of treating this as one big thing, can you list the areas in the Emby Server web interface that are the most important that need to be updated for RTL? If we can break this down into a list of smaller things then that will help speed things up considerably. Thanks.
CAPRICORNX10X 68 Posted June 30, 2022 Author Posted June 30, 2022 Of course I will do it! Happily! I start working on it right away 1
CAPRICORNX10X 68 Posted June 30, 2022 Author Posted June 30, 2022 Here are 3 lists. Definitely important points. I made changes in Photoshop to illustrate this better. If it is not well explained please tell me 1
Luke 42244 Posted July 1, 2022 Posted July 1, 2022 OK, little preview. @Abobader take a look at this: 1
Abobader 3485 Posted July 1, 2022 Posted July 1, 2022 9 minutes ago, Luke said: OK, little preview. @Abobader take a look at this: Look great Luke, well done indeed. Wife will like this.
CAPRICORNX10X 68 Posted July 1, 2022 Author Posted July 1, 2022 Luke It looks fantastic! You are a true champion! When you want, I can add more changes as needed to the list
CAPRICORNX10X 68 Posted July 2, 2022 Author Posted July 2, 2022 Hi luka Is it possible to move forward?
Luke 42244 Posted July 2, 2022 Posted July 2, 2022 5 hours ago, CAPRICORNX10X said: Hi luka Is it possible to move forward? HI, to move what forward?
CAPRICORNX10X 68 Posted July 3, 2022 Author Posted July 3, 2022 I just want to help fully assimilate. That everything will be adapted to the Hebrew language. I think it is really necessary for all the users who have this language. 1
Luke 42244 Posted July 5, 2022 Posted July 5, 2022 You can try out the progress so far with the online web app: http://app.emby.media You may need to use the app display settings to change your language to an RTL language first.
CAPRICORNX10X 68 Posted July 5, 2022 Author Posted July 5, 2022 Hey , first of all thank you very much. I saw the progress and oh it looks really good! Luca you are a champion ... From what I have seen there are still more changes that need to be made. As always and again, if you need my help I am available at any moment for you and the emby community
Luke 42244 Posted July 5, 2022 Posted July 5, 2022 At this point it's mostly just some of the icons that need to be flipped around.
CAPRICORNX10X 68 Posted July 5, 2022 Author Posted July 5, 2022 I would suggest that the order of the letters remain on the right side of the display. And not move it to the left.(It is more appropriate and acceptable when it is in the Hebrew language) And the marked back arrow should change direction
CAPRICORNX10X 68 Posted July 6, 2022 Author Posted July 6, 2022 @luke Luke, I went into my emby theater. And I saw the display is from right to left. And I do not remember that it was so .... what are you saying ?
Luke 42244 Posted July 6, 2022 Posted July 6, 2022 4 minutes ago, CAPRICORNX10X said: @luke Luke, I went into my emby theater. And I saw the display is from right to left. And I do not remember that it was so .... what are you saying ? Yes it has those updates now. I think the biggest issue remaining is that some icons need to be flipped to point in the other direction.
CAPRICORNX10X 68 Posted July 6, 2022 Author Posted July 6, 2022 Okay. Must note it looks good, amazing. Good job Luke @Abobader 1
CAPRICORNX10X 68 Posted July 6, 2022 Author Posted July 6, 2022 Luka what if make an option instead of a background when going into the details of the film. It will be possible to put a background with sound (video clip with sound) like in blu-ray titles
