ManuJapan89 2 Posted July 22, 2022 Posted July 22, 2022 (edited) Hi, as a Plex user i highly appreciate his Traschcan feature, that, if a hdd video repo goes offline, it will be marked as unavailable but still in library. Looking around for a solution i found out this software: Safely Remove Hardware better alternative | USB Safely Remove set it up in this exact way(obviously you can place this .bat wherever you want) the .bat DO this: TASKKILL /IM EmbyServer.exe* /T /F when you disconnect any usb,it will kill embyserver so you'll never run into a situation where you have to rebuild your library, totally or partially. i tested it either with standard and portable emby version. it works fine both situation. The only downside is this program is not free. there is a 30 day trial. it worth it IMHO. you can also try out a free option, working around this thread windows - Starting scheduled task by detecting connection of USB device - Super User you can launch a scheduled task action based on an event viewer EVENT. but i prefer using this simple program, altrough NOT FREE. Hope this help Have a nice day embykill.bat Edited July 22, 2022 by ManuJapan89 grammar correction 1
