Statick 15 Posted July 21, 2022 Posted July 21, 2022 as the title says please can Emby block the system from going to sleep while a library scan is taking place currently I have to disable sleep before starting a library scan, then re-enable it at some point after noticing the scan has finished, otherwise the system will go to sleep during the library scan
Luke 42246 Posted July 21, 2022 Posted July 21, 2022 Hi, that's odd. The file system access alone during the library scan is usually enough. What platform are your running the server on?
Statick 15 Posted July 25, 2022 Author Posted July 25, 2022 it's windows but the library is on a mapped networked drive so maybe it's that?
Luke 42246 Posted July 25, 2022 Posted July 25, 2022 4 hours ago, Statick said: it's windows but the library is on a mapped networked drive so maybe it's that? Possibly. Is the media on the same machine as the server?
Statick 15 Posted August 6, 2022 Author Posted August 6, 2022 no the data is on a NAS and Emby running on a Windows system
Luke 42246 Posted August 10, 2022 Posted August 10, 2022 OK we'll take a look at this. Thanks for reporting.
