Super957 24 Posted July 21, 2022 Posted July 21, 2022 There is a way to speed up client-side viewing and browse folders ? I use plugin Cover Art it is this plugin that can slow down the display of various movies Thank Hispa
Happy2Play 9800 Posted July 21, 2022 Posted July 21, 2022 What are your Database settings? Settings-Database
Super957 24 Posted July 21, 2022 Author Posted July 21, 2022 (edited) Here is it Thank Hsipa Edited July 21, 2022 by Super957 Modify
Super957 24 Posted July 21, 2022 Author Posted July 21, 2022 (edited) This is my situation on NAS, as you see majority are movies Hispa Edited July 21, 2022 by Super957
Super957 24 Posted July 21, 2022 Author Posted July 21, 2022 (edited) Please HELP...following this thread i put 1024 (MB) and select "Vacuum database" on the next Emby restart... but after restart Emby (14,00) are pass 4 hours and at this moment 18,00 Emby is not usable ! My movies and others are more or less 11TB, +/- 5..000 movies/serietv Is normal ? If it is not normal what can I do? Thank Hispa Edited July 21, 2022 by Super957
Luke 42186 Posted July 21, 2022 Posted July 21, 2022 Quote it is this plugin that can slow down the display of various movies Yes it can.
Hispanico957 23 Posted July 21, 2022 Posted July 21, 2022 (edited) Ok thank but vacuum work from 5 hours... Is normal? If in not normal what can I do? Hisoa And in my situato. 1024 MB is correct? Edited July 21, 2022 by Hispanico957
Hispanico957 23 Posted July 21, 2022 Posted July 21, 2022 (edited) 9 minutes ago, Luke said: Is what normal? If vacuum work from 6 hours and not finish... i must await or restart nas and emby but in this case pheraps database can be corrupt Hispa Edited July 21, 2022 by Hispanico957
Luke 42186 Posted July 21, 2022 Posted July 21, 2022 6 hours is pretty extreme, but yes the vacuum can take a long time if the disk is slow.
Super957 24 Posted July 21, 2022 Author Posted July 21, 2022 (edited) 6 minutes ago, Luke said: 6 hours is pretty extreme, but yes the vacuum can take a long time if the disk is slow. My 4 disks are WD Red Plus 8 TB NAS 3.5", Clas 7.200 RPM, SATA 6 GB/s, CMR, Cache 256 MB So in this consideration better await more or restart nas ? Hispa Edited July 21, 2022 by Super957
Luke 42186 Posted July 21, 2022 Posted July 21, 2022 Only you can decide how long you're willing to wait.
Super957 24 Posted July 21, 2022 Author Posted July 21, 2022 (edited) 5 minutes ago, Luke said: Only you can decide how long you're willing to wait. There is a way to understand if Emby Server work for "Vacuum" or not ? But are the chances of database corruption high? Please give me the best advice given your experience Hispa Edited July 21, 2022 by Super957
Super957 24 Posted July 21, 2022 Author Posted July 21, 2022 (edited) Ok restrt NAs and Emby and all is ok.... I have not had any problems with a corrupt database. So please 2 question: 1 - 1024MB in my configuration is OK ?? 2 - why vacuum go in looping ? i enclosed a log but the time is when start vacuum after no log exist Thank again Hispa embyserver-63794035619.rar Edited July 21, 2022 by Super957
Luke 42186 Posted July 21, 2022 Posted July 21, 2022 16 minutes ago, Super957 said: Ok restrt NAs and Emby and all is ok.... I have not had any problems with a corrupt database. So please 2 question: 1 - 1024MB in my configuration is OK ?? 2 - why vacuum go in looping ? i enclosed a log but the time is when start vacuum after no log exist Thank again Hispa embyserver-63794035619.rar 14.87 kB · 0 downloads It can be slow if the database is not on an SSD. The vacuum does not loop. There is no log for the vacuum process.
Super957 24 Posted July 21, 2022 Author Posted July 21, 2022 3 minutes ago, Luke said: It can be slow if the database is not on an SSD. The vacuum does not loop. There is no log for the vacuum process. Ok thank for vacuum and for dimension of Database 1024 MB is goo for have more performance with ny hardware/config ? Hispa
Carlo 4561 Posted July 22, 2022 Posted July 22, 2022 I hope you mean you got WD RED PLUS or RED PRO and not just RED drives. WD renamed their drives a couple years go to make it clear which drives use shingled vs convention recording. "WD Red" will exclusively mean disks using Shingled Magnetic Recording technology "WD Red Plus" will mean disks using Conventional Magnetic Recording with 5400RPM performance "WD Red Pro" will mean disks using Conventional Magnetic Recording with 7200RPM performance I wish I had logging turned on longer on my NAS as this will give you a unique view of performance across a few drives. This is a 4 drive btrfs volume so each of the drives is handling the same amount of data. Drive 1 is a 14TB WD Red Pro drive Drive 2 is a 14TB WD Red Plus drive Drive 3 is a 14TB WD white label "Red Plus" drive Drive 4 is revealed below. The white label Red Plus drives are also used in USB3 External enclosures that everyone shucks thinking they are getting "Red Plus" drives. These drives are the slowest of the bunch and do not include the same firmware as true NAS drives. They also can't be firmware updated to NAS firmware. BTW, I think I've got every version of the Reds as well as Seagate from 4TB to 18TB. I typically pick up a couple to test with as I always need more drives for backup so I get to test different drives this way. In general my advise is do NOT purchase WD drives with "Red" in the name. Do not purchase Seagate drives with "IronWolf" in the name. Neither are worth the money and better drives can be had cheaper. While you can run tests on individual drives and compare it's sometimes neat to combine different drives as part of the same RAID array so it's handling the exact same data as it's neighbor and comparing things this way. There is one stand-out drive of the 4 that is much faster and it's pretty clear. Drive 4 is a WD drive but from their Data Center collection of drives. It's still a SATA drive and actually cheaper then the NAS drive lineup!!! These go by the name UltraStore. These are all Helium filled drives with 512MB cache vs 64MB and up for Irons and Reds. 14TB Red Plus $285 https://www.amazon.com/Western-Digital-14TB-Internal-Drive/dp/B08V13TGP4 14TB Red Pro $368 https://www.amazon.com/Red-Pro-14TB-Hard-Drive/dp/B07YFGW736 14TB WD Elements Desktop Hard Drive HDD, USB 3.0 $259 https://www.amazon.com/14TB-Elements-Desktop-Drive-WDBWLG0140HBK-NESN/dp/B07YD3G568 14TB Ironwolf Pro NAS $329https://www.amazon.com/Seagate-IronWolf-7200RPM-256MB-3-5-Inch/dp/B07H57WY2Z 14TB Ironwolf NAS $308 https://www.amazon.com/Seagate-IronWolf-RAID-Internal-Drive/dp/B07H7CKYGT 14TB Ultrastar $259 https://www.amazon.com/Western-Digital-14TB-Ultrastar-HC530/dp/B07KPL474H 1
Carlo 4561 Posted July 22, 2022 Posted July 22, 2022 22 hours ago, Super957 said: Ok thank for vacuum and for dimension of Database 1024 MB is goo for have more performance with ny hardware/config ? Hispa Do you have a backup of critical Emby Server files? If not and you have Premiere install and setup the Backup Configuration Plugin from the catalog. Among other things this backs up all the databases. You can shutdown Emby Server and make a backup copy of the data directory as well before doing the next thing. with a backup of databases done. Try turning on the vacuum option again and restart the server. Let's see how long it takes to complete. The only time I've ever seen this not complete in under 6 minutes was when there was an issue in the library.db file that needed fixing. I'd like to make sure you don't have a problem with the memory upgrade or vacuum. I tend to run it once a month or when ever I made drastic changes to media. Now with over 25K movies, 150K+ shows plus home movies, sports, music, etc it's less than 2 minutes. But first time running a vacuum I'd be patient and give it time. Try this again and set a timer for 30 minutes. If it's not finished by then let us know as it's something we should check on and I can remote in and give you a hand with it. Please make sure you have a backup of the data folder either by hand or via the backup config plugin first. 1
Super957 24 Posted July 22, 2022 Author Posted July 22, 2022 (edited) 3 hours ago, cayars said: Do you have a backup of critical Emby Server files? If not and you have Premiere install and setup the Backup Configuration Plugin from the catalog. Among other things this backs up all the databases. You can shutdown Emby Server and make a backup copy of the data directory as well before doing the next thing. with a backup of databases done. Try turning on the vacuum option again and restart the server. Let's see how long it takes to complete. The only time I've ever seen this not complete in under 6 minutes was when there was an issue in the library.db file that needed fixing. I'd like to make sure you don't have a problem with the memory upgrade or vacuum. I tend to run it once a month or when ever I made drastic changes to media. Now with over 25K movies, 150K+ shows plus home movies, sports, music, etc it's less than 2 minutes. But first time running a vacuum I'd be patient and give it time. Try this again and set a timer for 30 minutes. If it's not finished by then let us know as it's something we should check on and I can remote in and give you a hand with it. Please make sure you have a backup of the data folder either by hand or via the backup config plugin first. I have 4 WD RED PLUS (8TB x 4 for 32TB) Ok understand all and i try again. Yes i have backup plugin and every month i cipy all file following this Emby Backup : So if i have problem i have teamviewer always connect but i need from you more or less your contact time, i live in Italy Thank Hispa Edited July 22, 2022 by Super957 1
Carlo 4561 Posted July 23, 2022 Posted July 23, 2022 I'm in the Eastern Time Zone same as NY City. The safe range is 8am to 2am my time but can do other times as well if we schedule. One or two days a week I work through the night to help people in China, Australia, NZ, Western Europe, etc since it's such a time zone difference. It's takes me a good 50% longer helping people from Asian countries due to language settings on devices/PC and having to translate language/communications during chat. China is especially tricky as there is usually VPNs or "smart DNS" at play to work around the "great firewall" but always seems to cause other issues. So if you need me to be available or "on-call" just in case, send me a PM and we'll set it up. 1
Super957 24 Posted July 23, 2022 Author Posted July 23, 2022 (edited) Hi cayars thank i make backup and restrt Emby selecting Vacuum and this time in less 2 minutes restart normally I think the Vacuum operatin go well.... but i cannot verify because vacuum not produce logs but in emby server logs i see some error...can you verify ? Thank Hispa embyserver (18).txt Edited July 23, 2022 by Super957
Luke 42186 Posted July 24, 2022 Posted July 24, 2022 On 7/23/2022 at 2:28 PM, Super957 said: Hi cayars thank i make backup and restrt Emby selecting Vacuum and this time in less 2 minutes restart normally I think the Vacuum operatin go well.... but i cannot verify because vacuum not produce logs but in emby server logs i see some error...can you verify ? Thank Hispa embyserver (18).txt 41.88 kB · 1 download Those are just coming from the port mapper. Nothing to worry about. You can always disable that feature if you don't need it. 1
Super957 24 Posted July 25, 2022 Author Posted July 25, 2022 9 hours ago, Luke said: Those are just coming from the port mapper. Nothing to worry about. You can always disable that feature if you don't need it. Oooook thank LUKE No i dont use is and where i can disable it ? Hispa
Luke 42186 Posted July 25, 2022 Posted July 25, 2022 1 hour ago, Super957 said: Oooook thank LUKE No i dont use is and where i can disable it ? Hispa Have you explored Emby Server network settings?
Super957 24 Posted July 25, 2022 Author Posted July 25, 2022 3 hours ago, Luke said: Have you explored Emby Server network settings? Yessss found it Thank Hispa
