z4heshey 0 Posted July 20, 2022 Posted July 20, 2022 i have more then 4000 covers of albums on my files but they dont show up on my library i tried to disable all of the metadata but that didint work it still keeps putting its own stuff or it puts nothing please help me anyone
Happy2Play 9812 Posted July 20, 2022 Posted July 20, 2022 8 minutes ago, z4heshey said: i have more then 4000 covers of albums on my files but they dont show up on my library i tried to disable all of the metadata but that didint work it still keeps putting its own stuff or it puts nothing please help me anyone Are these embedded images in the track or in the folder? If embedded, you need to enable image extractor on Songs. Can you go over a specific example?
Luke 42243 Posted July 21, 2022 Posted July 21, 2022 26 minutes ago, Happy2Play said: If embedded, you need to enable image extractor on Songs. And this is enabled by default, so there would only be a problem if it was turned off in library options.
Luke 42243 Posted August 24, 2022 Posted August 24, 2022 On 8/22/2022 at 4:54 PM, z4heshey said: how would i do it @z4heshey if you click on your music library in Emby library setup, then scroll down to the Image Fetcher options. What Image Fetchers do you have enabled?
