softworkz 5133 Posted April 5, 2023 Posted April 5, 2023 1 minute ago, rbjtech said: blocking API for remote use should be a configurable item You can't block the API, because that's the way how clients communicate with Emby server The only thing you could probably do is filter out requests having a http header api_key or X-Emby-Token - but I can't say whether this might not have other implications, especially for the latter.
rbjtech 5344 Posted April 5, 2023 Posted April 5, 2023 1 minute ago, softworkz said: You can't block the API, because that's the way how clients communicate with Emby server The only thing you could probably do is filter out requests having a http header api_key or X-Emby-Token - but I can't say whether this might not have other implications, especially for the latter. doh! I'll have a play - thanks for the responses. 1
