Romain06 1 Posted July 17, 2022 Posted July 17, 2022 Hello, since the last update, when I go forward or back there are no more images on the thumbnail than the time of the film. I looked at the options on the server and the player but I did not find anything to put this option back. Please let me know if this is possible? cdt
Romain06 1 Posted July 20, 2022 Author Posted July 20, 2022 Hi Luke, on the phone(IOS), the web application and the windows 10 application it is the same. We only see time, no images. It happened since an update. Cdt.
Luke 42237 Posted July 20, 2022 Posted July 20, 2022 Hi there, have you enabled the video preview thumbnail option in your library settings?
Romain06 1 Posted July 21, 2022 Author Posted July 21, 2022 Hi Luke, I only saw one option in media library, movies and video thumbnails. I changed the options and restarted the server, nothing changed.
Solution Luke 42237 Posted July 21, 2022 Solution Posted July 21, 2022 After changing those options you'll need to refresh metadata on existing content.
Romain06 1 Posted July 24, 2022 Author Posted July 24, 2022 Hi Luke thanks for help, now its work fine. I don't know why this option was no longer enabled. Cdt. 1
