Luke 42290 Posted July 22, 2022 Posted July 22, 2022 7 minutes ago, Luke said: Try using the image editor to delete the one you don't want.
CAPRICORNX10X 68 Posted July 22, 2022 Author Posted July 22, 2022 emby automatically takes a background from tmdb, then when I independently put a background in the local folder it is not selected . emby leave the selected background from tmdb
CAPRICORNX10X 68 Posted July 22, 2022 Author Posted July 22, 2022 9 minutes ago, Luke said: Try using the image editor to delete the one you don't want. I can do it . But it's not comfortable
ebr 16354 Posted July 23, 2022 Posted July 23, 2022 Hi. The basic issue here is that you don't have the option to save images along side your media turned on but then you went and added an image along side your media. So, now you have images in two different places (the default metadata store and the local media folders). If you want images to be along side your media, then you should turn on that option in the library settings.
CAPRICORNX10X 68 Posted July 23, 2022 Author Posted July 23, 2022 5 hours ago, ebr said: Hi. The basic issue here is that you don't have the option to save images along side your media turned on but then you went and added an image along side your media. So, now you have images in two different places (the default metadata store and the local media folders). If you want images to be along side your media, then you should turn on that option in the library settings. And how do I do it? In library options, there is only a mark for logo and primer (poster)... I don't see any background option (local folder)
