Waldoo 14 Posted July 15, 2022 Posted July 15, 2022 I have it on in the tv shows setting do I have to do it else where too?
Luke 42239 Posted July 15, 2022 Posted July 15, 2022 hi there, can you please provide discussion of an example? Thanks.
samuelqwe 317 Posted July 15, 2022 Posted July 15, 2022 1 hour ago, Waldoo said: I have it on in the tv shows setting do I have to do it else where too? After you’ve enabled the markers in your TV Shows library, have you run the task? There shouldn’t be anything else to enable.
TeamB 2440 Posted July 16, 2022 Posted July 16, 2022 8 hours ago, Waldoo said: I have it on in the tv shows setting do I have to do it else where too? you can check is IntroStart and IntroEnd chapters were correctly created by using the following (in dev beta) plugin. https://emby.media/community/index.php?/topic/110525-plugin-chapter-editor-chapterapi/ This will allow let you check the intro markers and confirm they were created correctly.
