libaroba 1 Posted July 14, 2022 Posted July 14, 2022 Version 2.0.77g on Nvidia Shield TV Pro 2019 There is a very annoying problem with the subtitle and soundtrack selection in the app. I select an audio track and subtitles that are different from the default tracks. During playback, I pause the video and let the app go to the screensaver. Upon waking, the app only remembers the running time to resume. The audio and subtitle track settings are back to the default tracks. There is a similar problem with TV shows. I select audio and subtitles in an episode and when I start the next episode the tracks are set to default, even though the whole show has the same languages, codecs and even order of audio/subtitle tracks.
ebr 16336 Posted July 14, 2022 Posted July 14, 2022 3 minutes ago, libaroba said: I select audio and subtitles in an episode and when I start the next episode the tracks are set to default, even though the whole show has the same languages, codecs and even order of audio/subtitle tracks. Hi. In regards to that, please see:
Jeansy 4 Posted July 6, 2025 Posted July 6, 2025 Hi, I do have an Android TV and am experiencing the same issues. I have screensaver enabled. Now I select my audio and subtitle tracks and start watching a movie or series episode. When I pause the playback, the screensaver will start after a short while. After resume from the screensaver I will be back on the movie or episode screen and I can literally watch the audio and subtitle tracks resetting from my chosen values back to my default settings. I have enabled the option to keep the last played audio and subtitle tracks. It manages to keep the selected tracks even between episodes of a series. But it seems to be buggy, if the playback is interrupted by the screensaver.
ebr 16336 Posted July 6, 2025 Posted July 6, 2025 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
Jeansy 4 Posted July 6, 2025 Posted July 6, 2025 I installed Emby for Android and it does not have the issue as it will not go back to the movie/episode page, but remain in the player after resuming from the screensaver. As for the moment I am ok with that, as the app seems to work fine on Android TV. But it would be nice for a future version if this could be addressed 1
