HawkXP71 112 Posted July 14, 2022 Posted July 14, 2022 in the API call /Users/{UserId}/PlayingItems/{Id}/Progress it states 1 tick = 10,000 ms This means in order to get the actual number of ms from a tick value, you multiply by 10,000 Except its actually 1 ms = 10,000 ticks. and you have to divide by 10,000 For a particular TV show Im experimenting with, Its paused 2:47 using the emby player. 2:47 = 167 seconds, or 167,000 ms, that means the reported tick position if 1 tick = 10,000 ms, should be 1670 ticks. However, the returned value is 1,679,452,040 ticks, or 167,945 ms if you divide. I believe this is simply a mistake in the documentation, but its possible the API is returning the wrong value
harrv 90 Posted July 24, 2022 Posted July 24, 2022 One way to word it is that there are ten million ticks per second. 1
Luke 42237 Posted July 24, 2022 Posted July 24, 2022 On 7/13/2022 at 9:18 PM, HawkXP71 said: In swagger for the call above Can you show a screenshot of what you mean? Thanks.
HawkXP71 112 Posted July 24, 2022 Author Posted July 24, 2022 3 hours ago, Luke said: Can you show a screenshot of what you mean? Thanks.
Luke 42237 Posted July 24, 2022 Posted July 24, 2022 OK I think the documentation is correct, right? 1 tick = 10000ms. That is true.
HawkXP71 112 Posted July 25, 2022 Author Posted July 25, 2022 2 hours ago, Luke said: OK I think the documentation is correct, right? 1 tick = 10000ms. That is true. Microsofts docs say otherwise https://docs.microsoft.com/en-us/dotnet/api/system.datetime.ticks?view=net-6.0 "A single tick represents one hundred nanoseconds or one ten-millionth of a second. There are 10,000 ticks in a millisecond (see TicksPerMillisecond) and 10 million ticks in a second." Meaning its 1ms = 10000 ticks
HawkXP71 112 Posted July 25, 2022 Author Posted July 25, 2022 8 minutes ago, Luke said: Sorry I misread. 1 ms = 10000 ticks. Yep. I assume you will file the doc bug? 1
