teils0x 1 Posted July 11, 2022 Posted July 11, 2022 on fire tv when I put a video when the 35th minute arrives, the image is accelerated and the sound is normal, I play the video on another system and it goes perfectly. he doesn't do it in all the videos but the one that does it to me and I play it again at that minute the same thing happens.
Luke 42245 Posted July 12, 2022 Posted July 12, 2022 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
pacovw 1 Posted July 16, 2022 Posted July 16, 2022 Hi I've same problem, in the same time. I've this issue only on my Xiaomi MIBOX4 player, same video don't have this problem on browser player or Emby player on my Android smartphone . I attach logs from server on my Synology NAS DS218play DSM 7.1-42661 Update 2 Emby Server version 4.7.5.0 Annual Emby Premiere plan embyserver.txt ffmpeg-transcode-29e2ddb9-d7b7-436c-b753-c5e944838b00_1.txt
ebr 16337 Posted July 17, 2022 Posted July 17, 2022 19 hours ago, pacovw said: Hi I've same problem, in the same time. Hi. You are saying you see an acceleration of playback at exactly 35 minutes also? 19 hours ago, pacovw said: I've this issue only on my Xiaomi MIBOX4 player The transcode log you provided is from web browser playback. It may be that the transcoding is correcting whatever this issue is. If you use the "Playback correction" option under the cog menu during playback on your Mi, does it correct the problem?
ktdt0069 2 Posted July 24, 2022 Posted July 24, 2022 (edited) On 7/11/2022 at 3:51 PM, teils0x said: on fire tv when I put a video when the 35th minute arrives, the image is accelerated and the sound is normal, I play the video on another system and it goes perfectly. he doesn't do it in all the videos but the one that does it to me and I play it again at that minute the same thing happens. I have the same issue on a FireTV stick. Several videos, maybe 1 in 6, begin accelerating video at 35:47. I've watched the racing for up to a minute and regardless of how long I watch it for, after I stop it, the resume position is always 35:47. I can play the same video on the web client without the racing. I'll read through the link above on how to submit diagnostic information and try and get something uploaded. In the meantime, I just wanted to add my two cents for posterity as this is definitely "a thing" and not an anomaly. Edit: Restarted emby server, began playing video, FF'd to 30:00 and then let it run to the problem at 35:47. I continued to let it run in the race condition for an additional 10 seconds, then stopped the video. Server log attached. embyserver.txt Edited July 24, 2022 by ktdt0069 Add logs 1
teils0x 1 Posted July 24, 2022 Author Posted July 24, 2022 Exacto me pasa exactamente eso , tambien si le doy a corregir el problema se arregla pero en otros vidios pasalo mismo solo es temporal el arreglo
Luke 42245 Posted July 31, 2022 Posted July 31, 2022 HI, can you try sideloading our standard android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks !
teils0x 1 Posted July 31, 2022 Author Posted July 31, 2022 En la aplacion de movil me funciona bien y en el stick de fire tv no no me deja instalar la app de emby normal
ebr 16337 Posted July 31, 2022 Posted July 31, 2022 4 hours ago, teils0x said: in the fire tv stick it does not let me install the normal emby app Hi. You need to side-load the APK from that link.
pacovw 1 Posted August 2, 2022 Posted August 2, 2022 On 7/31/2022 at 5:11 PM, ebr said: Hi. You need to side-load the APK from that link. Same fast moving video, and normal speed music on Android app from site version 3.2.61 and from fire stick store version 2.0.77a - server version 4.7.6.0 on Synology Nas Vid 20220802 231827.mkv
teils0x 1 Posted August 3, 2022 Author Posted August 3, 2022 yo ahora tengo mas problemas e instalado la apk de emby para android , pero no me deja reproducir nada por que me dice que tengo que tener emby premier , yo ya que pague a trabes de la aplicación de amazon y podía reproducir los videos.
ebr 16337 Posted August 3, 2022 Posted August 3, 2022 10 minutes ago, teils0x said: Now I have more problems and installed the emby apk for android, but it won't let me play anything because it tells me I have to have emby premier, I already paid through the amazon application and could play the videos. Hi. The standard app currently does require Premiere on a TV device. Before the move we will come up with a way to validate previous purchases of the other app.
ebr 16337 Posted August 6, 2022 Posted August 6, 2022 Hi. Can we see an example with a file that is not in the AVI container?
pacovw 1 Posted August 7, 2022 Posted August 7, 2022 Only for AVI Container for now is bug in always 35:47 min. 1
BeniSt 2 Posted August 17, 2022 Posted August 17, 2022 Hi all I have the same problem with avi on my amazon fire stick 4k. mkv is no problem. The emby version is 2.0.77a. Thx for fixing :-)
Luke 42245 Posted August 17, 2022 Posted August 17, 2022 Just now, BeniSt said: Hi all I have the same problem with avi on my amazon fire stick 4k. mkv is no problem. The emby version is 2.0.77a. Thx for fixing Hi, can you try side loading our standard Android app on the same device and let us know how that compares: https://emby.media/emby-for-android.html Thanks
BeniSt 2 Posted August 17, 2022 Posted August 17, 2022 I have emby deinstalled on the stick and installed your apk (arm7) from the website over the app "downloader". Then i start emby and play the serie again from the same time that make problems...its the same problem.
BeniSt 2 Posted August 17, 2022 Posted August 17, 2022 Here a video with the apk from you...sorry is in german, but u can see it. 20220817_181437.mp4
Luke 42245 Posted August 17, 2022 Posted August 17, 2022 So I'm guessing this is only happening with avi files?
BeniSt 2 Posted August 17, 2022 Posted August 17, 2022 Ok, but how can i send you this sample? Its more than 195mb...and you ned mor then 37 min, i cant cut it.
Luke 42245 Posted August 17, 2022 Posted August 17, 2022 Dropbox or google drive would be great. Thanks.
