flippyfingw 0 Posted July 11, 2022 Posted July 11, 2022 Using Emby Theater 3.0.15, it will not use hardware accel for AV1 files on my pc. Specs: RTX 3080Ti, Windows 10, latest Nvidia drivers. However, if i replace the libmpv in C:\Users\<>\AppData\Roaming\Emby-Theater\system\electronapp\libmpv\x64\ with the downloaded libmpv from Sourceforge and rename it to mpv-1.dll hardware acceleration works perfectly. I have the AV1 codec extensions installed. The version code suggests that the original libmpv could be as old as from 2020. I'm not sure how many things straight up replacing the dll will break, but as of now this seems to work.
Luke 42239 Posted July 13, 2022 Posted July 13, 2022 Hi, can you try the current test build and see how it compares? Thanks.
flippyfingw 0 Posted July 14, 2022 Author Posted July 14, 2022 Hey, the test build is working fine, deleted older dlls and verified.
Luke 42239 Posted July 14, 2022 Posted July 14, 2022 Great, thanks. This will be in the next update to the app.
