ozijon 0 Posted October 15, 2013 Posted October 15, 2013 Hi i paid for cover art and ROC theme and both are saying expiredwhy is this I have added my keycan someone helpthank you
aspdend 177 Posted October 15, 2013 Posted October 15, 2013 Have you tried restarting the MB3 Server? I know that my ROC tends to state expired after an update, but restarting the server seems to cure this
mboehler 94 Posted October 15, 2013 Posted October 15, 2013 Sometimes you will get that message if MB Classic can't communicate with the MB3 website to validate the license key.
ebr 16354 Posted October 15, 2013 Posted October 15, 2013 Where are they "saying they are expired"? If you go into the details for the plug-ins from the plug-in catalog in the dashboard, do they report as registered there? What does the supporter key page for your dashboard look like? Any warning messages on it?
ozijon 0 Posted October 16, 2013 Author Posted October 16, 2013 Where are they "saying they are expired"? If you go into the details for the plug-ins from the plug-in catalog in the dashboard, do they report as registered there? What does the supporter key page for your dashboard look like? Any warning messages on it You can see in pic ROC theme seems ok now as it said update but still covrr art keeps saying expired thank you
Solution ebr 16354 Posted October 16, 2013 Solution Posted October 16, 2013 You aren't registered for CoverArt, it appears. Looks like you only registered the upgrade from 2.0 to 3.0 which is only valid if you were registered for 2.0.
ozijon 0 Posted October 16, 2013 Author Posted October 16, 2013 You aren't registered for CoverArt, it appears. Looks like you only registered the upgrade from 2.0 to 3.0 which is only valid if you were registered for 2.0. ok just paid now says registered thank you for explaing
ebr 16354 Posted October 16, 2013 Posted October 16, 2013 Just FYI - when you mark something solved, mark the answer that actually solved it. That way the right answer appears up top. Thx.
