Guest WarriorPaw Posted July 9, 2022 Posted July 9, 2022 OS: ubuntu 22.04 CPU / GPU : N5105 Hardware decode not working with both VAAPI or QuickSync. How to solve this , thanks. QuickSync error ffmpeg-transcode-9fd94388-938e-42e1-af1b-9ca250887e19_1.txt VAAPI error ffmpeg-transcode-79991c74-41fe-4215-aebf-5ea89b4487e4_1.txt embyserver.txt
Q-Droid 1011 Posted July 9, 2022 Posted July 9, 2022 These should have useful info. https://emby.media/community/index.php?/search/&q="jasper lake"&quick=1&search_and_or=or&sortby=relevancy
Guest WarriorPaw Posted July 9, 2022 Posted July 9, 2022 trying add "options i915 enable_guc=2" into kernel parameter describe by this post. Then all decoder is gone... WTF ???
Guest WarriorPaw Posted July 9, 2022 Posted July 9, 2022 7 minutes ago, Q-Droid said: These should have useful info. https://emby.media/community/index.php?/search/&q="jasper lake"&quick=1&search_and_or=or&sortby=relevancy thanks alot~~ As this pots said, N5105 is too new for now. seems the best solution is waiting, until new "intel driver or firmware or some thing else" pack into emby server packages. SO SAD...
Guest WarriorPaw Posted January 14, 2023 Posted January 14, 2023 On 7/10/2022 at 7:06 AM, softworkz said: Don't worry, it's coming shortly... It's been half a year, wondering if this problem has been fixed? Thanks
Luke 42245 Posted January 15, 2023 Posted January 15, 2023 16 hours ago, WarriorPaw said: It's been half a year, wondering if this problem has been fixed? Thanks Hi, what version of the server are you on now?
softworkz 5133 Posted January 15, 2023 Posted January 15, 2023 17 hours ago, WarriorPaw said: It's been half a year, wondering if this problem has been fixed? Thanks Have you tried the solution that worked for the other user in the topic I referenced?
