jathe 9 Posted July 23, 2022 Author Posted July 23, 2022 On 7/21/2022 at 2:20 PM, Luke said: Can you provide a log example from 4.5? thanks. Asking for working logs?? Really?? I send the log for the not working 4.7 I don't need help on the 4.5. So basically, just respond this question: There is a way to getting this working without transcoding like 4.5.0 version?? If no, then this is an abuse asking for emby-premiere to livetv, unlock app from some devices, now asking for a powerfull server hahahahaha After 2 years paying emby-premiere moving to Jellyfin(less problematic, cheapper and clear).
pwhodges 2033 Posted July 23, 2022 Posted July 23, 2022 24 minutes ago, jathe said: Asking for working logs?? Really?? I send the log for the not working 4.7 I don't need help on the 4.5. Luke wants the other logs so that he can compare, and get more idea of what's changed to cause the problem. Paul 1
Luke 42241 Posted July 23, 2022 Posted July 23, 2022 HI, yes, exactly. I'd like to get the bottom of this and understand the difference.
jathe 9 Posted July 24, 2022 Author Posted July 24, 2022 Mp4 and mkv files in h264 and 2 audio channels also transcoding... Now I got a file about 4gb with a movie, when somebody plays it consumes another 4gb on var/lib/emby/transcoding-temp. Example: Movie.mkv (4gb) Roku playing (4gb of transcoding) Another roku playing(4gb of transcoding) Do the math... a movie consume the 100% of the file size everytime that get played... It is a joke!! Seriusly guys, why you guys forces to update servers when new versions are very bad? Get new table view and improve the visual context is very good, but I think most of us need better performance and stability... And don't ask for logs, this issue is not about me, you can do tests and got the same issues... is not about a bad config or bad file, h264 and ac2 is the standard for all the devices.. at least for iphone, roku and android app. mkv and mp4 is the same result I only add remuxing option to my user, the last one.
ebr 16334 Posted July 24, 2022 Posted July 24, 2022 2 hours ago, jathe said: Roku playing (4gb of transcoding) Another roku playing(4gb of transcoding) Do the math... a movie consume the 100% of the file size everytime that get played... Hi. The system will delete as needed when space gets low. Otherwise, there is really no reason to remove these until you are finished.
speechles 2062 Posted July 24, 2022 Posted July 24, 2022 (edited) Are your subtitles not Roku friendly? When those users enable those subtitles it will cause transcoding because the subtitles are not supported. What winds up happening is your Emby server will "burn" these into the video stream which causes transcoding on files that would otherwise direct play. What is the reason given for the transcoding on stats for nerds? Without more information we can only speculate. If this is about the IPTV plugin not direct playing the container and only copying the streams, then that is what happens, on purpose. We cannot direct play user submitted URLS from Emby on store applications. When that happens the app stores become aware of what exactly you are playing and from where. The app stores "see" the URLS you play. Where they originate from. This can mean if you are using pirated links or something else similar it can place Emby as complicit in your actions. To prevent the app stores from ever thinking Emby is associated with stream piracy we cannot direct play and can only copy streams from IPTV. Do you understand? Jellyfin does not care about you as a user. Do not become confused. They are not protecting you from app stores banning your devices. They are not protecting themselves. A foolish man believes everyone is only capable of good. You must protect the innocent and good from the bad around us. If that upsets you I apologize. Edited July 24, 2022 by speechles 2
jathe 9 Posted July 24, 2022 Author Posted July 24, 2022 5 hours ago, speechles said: Are your subtitles not Roku friendly? When those users enable those subtitles it will cause transcoding because the subtitles are not supported. What winds up happening is your Emby server will "burn" these into the video stream which causes transcoding on files that would otherwise direct play. What is the reason given for the transcoding on stats for nerds? Without more information we can only speculate. If this is about the IPTV plugin not direct playing the container and only copying the streams, then that is what happens, on purpose. We cannot direct play user submitted URLS from Emby on store applications. When that happens the app stores become aware of what exactly you are playing and from where. The app stores "see" the URLS you play. Where they originate from. This can mean if you are using pirated links or something else similar it can place Emby as complicit in your actions. To prevent the app stores from ever thinking Emby is associated with stream piracy we cannot direct play and can only copy streams from IPTV. Do you understand? Jellyfin does not care about you as a user. Do not become confused. They are not protecting you from app stores banning your devices. They are not protecting themselves. A foolish man believes everyone is only capable of good. You must protect the innocent and good from the bad around us. If that upsets you I apologize. That is what I need.... a clear response... "We dont support direct play on new version because the appstore can ban your device or our app"... instead of asking for logs... Maybe you should tell customers that you need to transcode every media and have the embyserver updated before asking for money in appstores like ios, android and lg.... Imo
ebr 16334 Posted July 24, 2022 Posted July 24, 2022 2 hours ago, jathe said: That is what I need.... a clear response... "We dont support direct play on new version because the appstore can ban your device or our app"... instead of asking for logs... Hi. Nothing in this behavior is new nor does it require transcoding. Comparing your logs might help us see what the difference is though.
jathe 9 Posted July 27, 2022 Author Posted July 27, 2022 23 users online... because remuxing(not transcoding)
Luke 42241 Posted July 27, 2022 Posted July 27, 2022 On 7/24/2022 at 6:43 AM, jathe said: Mp4 and mkv files in h264 and 2 audio channels also transcoding... Now I got a file about 4gb with a movie, when somebody plays it consumes another 4gb on var/lib/emby/transcoding-temp. Example: Movie.mkv (4gb) Roku playing (4gb of transcoding) Another roku playing(4gb of transcoding) Do the math... a movie consume the 100% of the file size everytime that get played... It is a joke!! Seriusly guys, why you guys forces to update servers when new versions are very bad? Get new table view and improve the visual context is very good, but I think most of us need better performance and stability... And don't ask for logs, this issue is not about me, you can do tests and got the same issues... is not about a bad config or bad file, h264 and ac2 is the standard for all the devices.. at least for iphone, roku and android app. mkv and mp4 is the same result I only add remuxing option to my user, the last one. Can you provide a server log example from 4.5 for comparison purposes? thanks !
jathe 9 Posted August 8, 2022 Author Posted August 8, 2022 1tb SSD Disk and 128Gb RAM solve the problem (Only Remuxing enabled for user). Version 4.5.4 was running on a 4GB RAM/250GB SSD without any problem. This is a joke!! Plus emby premiere forced for android, iphone and LG. Very nice and expensive work!!
MaxMax 0 Posted August 8, 2022 Posted August 8, 2022 (edited) 2 hours ago, jathe said: 1tb SSD Disk and 128Gb RAM solve the problem (Only Remuxing enabled for user). Version 4.5.4 was running on a 4GB RAM/250GB SSD without any problem. This is a joke!! Plus emby premiere forced for android, iphone and LG. Very nice and expensive work!! Check Network interfaces Edited August 8, 2022 by MaxMax
jathe 9 Posted August 11, 2022 Author Posted August 11, 2022 What I found: 1.- IPTV Plugin don't work anymore on Roku with HLS streams. I switched to TS. 2.- IPTV Plugin crash and send to home screen on roku when the Item has not any info or metadata: 3.- I try to play item on web interface, and don't play TS streams (web only works with HLS). After playing error, Item got information about codecs and so... 4.- After item got info... voila!! Roku Load the stream This is the log with a Item without info. Trying to play on Roku: 2022-08-10 23:04:18.458 Info Server: http/1.1 POST http://server:8096/emby/Items/147092/PlaybackInfo?UserId=0000000000&isplayback=false&maxstreamingbitrate=2677825&starttimeticks=00000000. UserAgent: Roku/DVP-11.0 (11.0.0.4193-AE) 2022-08-10 23:04:18.460 Info App: User policy for admin. EnablePlaybackRemuxing: False EnableVideoPlaybackTranscoding: False EnableAudioPlaybackTranscoding: False 2022-08-10 23:04:18.460 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 40000000, max bitrate: 2677825 2022-08-10 23:04:18.460 Info App: Bitrate exceeds DirectStream limit: media bitrate: 40000000, max bitrate: 2677825 2022-08-10 23:04:18.460 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 40000000, max bitrate: 2677825 2022-08-10 23:04:18.460 Info App: Bitrate exceeds DirectStream limit: media bitrate: 40000000, max bitrate: 2677825 2022-08-10 23:04:18.461 Info Server: http/1.1 Response 200 to 0000. Time: 3ms. http://server:8096/emby/Items/147092/PlaybackInfo?UserId=0000000000&isplayback=false&maxstreamingbitrate=2677825&starttimeticks=00000000 2022-08-10 23:04:18.485 Info Server: http/1.1 GET http://server:8096/emby/Videos/144817/stream.mpegts?static=true&mediaSourceId=0000000000. Accept=*/*, server:8096, User-Agent=Roku/DVP-11.0 (11.0.0.4193-51) 2022-08-10 23:04:18.489 Error Server: Error processing request *** Error Report *** Version: 4.7.6.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 4.15.0-189-generic (buildd@lcy02-amd64-039) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)) #200-Ubuntu SMP Wed Jun 22 19:53:37 UTC 20 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 3 Data path: /var/lib/emby Application path: /opt/emby-server/system System.ArgumentNullException: System.ArgumentNullException: Value cannot be null. (Parameter 'mediaSource') at Emby.Server.MediaEncoding.Encoder.EncodingHelpers.AttachMediaSourceInfo(EncodingJobInfo state, MediaSourceInfo mediaSource, String requestedUrl, IFfmpegManager ffmpegManager) at Emby.Server.MediaEncoding.Api.BaseStreamingService.GetState(StreamRequest request, AuthorizationInfo authorizationInfo, String manifestAbsoluteUri, Boolean requiresOutputPath, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.Progressive.BaseProgressiveStreamingService.ProcessRequest(StreamRequest request, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void AttachMediaSourceInfo(Emby.Server.MediaEncoding.Encoder.EncodingJobInfo, MediaBrowser.Model.Dto.MediaSourceInfo, System.String, MediaBrowser.Controller.MediaEncoding.IFfmpegManager) I hope this get fixed ... or how I can add the items metadata instead of playing one by one on web client?
ebr 16334 Posted August 11, 2022 Posted August 11, 2022 It looks like the item hasn't even been probed so we have no media information on it either. Can you explain why you are trying to use the IPTV plug-in instead of the Live TV m3u tuner setup? That plug-in is really only used for things like IP camera feeds and such these days so it does not get much testing.
jathe 9 Posted August 11, 2022 Author Posted August 11, 2022 I did try with m3u tunner(I have premiere subscription). Like I said, transcoding give me a headache, first full my disk so I updated from 100Gb Mechanichal to 1TB SSD, this stop filling up the disk but it takes about 60% 70% (700GB) and still crashing at somepoint... I thought the Disk Space is not the only problem so I updated Memory from 16GB to 128Gb but the server still crashing at some point. I only use no more than 30 devices .... CPU is a Xeon V3. Anyway this is not about my use, I post this since another versions of server (4.5.4 to be exact) don't crash with items with no media info. I think is a bug of new server versions, I tried with all 4.6 versions and all do crashes the roku client....
Luke 42241 Posted August 12, 2022 Posted August 12, 2022 On 8/11/2022 at 12:15 AM, jathe said: What I found: 1.- IPTV Plugin don't work anymore on Roku with HLS streams. I switched to TS. 2.- IPTV Plugin crash and send to home screen on roku when the Item has not any info or metadata: 3.- I try to play item on web interface, and don't play TS streams (web only works with HLS). After playing error, Item got information about codecs and so... 4.- After item got info... voila!! Roku Load the stream This is the log with a Item without info. Trying to play on Roku: 2022-08-10 23:04:18.458 Info Server: http/1.1 POST http://server:8096/emby/Items/147092/PlaybackInfo?UserId=0000000000&isplayback=false&maxstreamingbitrate=2677825&starttimeticks=00000000. UserAgent: Roku/DVP-11.0 (11.0.0.4193-AE) 2022-08-10 23:04:18.460 Info App: User policy for admin. EnablePlaybackRemuxing: False EnableVideoPlaybackTranscoding: False EnableAudioPlaybackTranscoding: False 2022-08-10 23:04:18.460 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 40000000, max bitrate: 2677825 2022-08-10 23:04:18.460 Info App: Bitrate exceeds DirectStream limit: media bitrate: 40000000, max bitrate: 2677825 2022-08-10 23:04:18.460 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 40000000, max bitrate: 2677825 2022-08-10 23:04:18.460 Info App: Bitrate exceeds DirectStream limit: media bitrate: 40000000, max bitrate: 2677825 2022-08-10 23:04:18.461 Info Server: http/1.1 Response 200 to 0000. Time: 3ms. http://server:8096/emby/Items/147092/PlaybackInfo?UserId=0000000000&isplayback=false&maxstreamingbitrate=2677825&starttimeticks=00000000 2022-08-10 23:04:18.485 Info Server: http/1.1 GET http://server:8096/emby/Videos/144817/stream.mpegts?static=true&mediaSourceId=0000000000. Accept=*/*, server:8096, User-Agent=Roku/DVP-11.0 (11.0.0.4193-51) 2022-08-10 23:04:18.489 Error Server: Error processing request *** Error Report *** Version: 4.7.6.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 4.15.0-189-generic (buildd@lcy02-amd64-039) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)) #200-Ubuntu SMP Wed Jun 22 19:53:37 UTC 20 Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 3 Data path: /var/lib/emby Application path: /opt/emby-server/system System.ArgumentNullException: System.ArgumentNullException: Value cannot be null. (Parameter 'mediaSource') at Emby.Server.MediaEncoding.Encoder.EncodingHelpers.AttachMediaSourceInfo(EncodingJobInfo state, MediaSourceInfo mediaSource, String requestedUrl, IFfmpegManager ffmpegManager) at Emby.Server.MediaEncoding.Api.BaseStreamingService.GetState(StreamRequest request, AuthorizationInfo authorizationInfo, String manifestAbsoluteUri, Boolean requiresOutputPath, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.Progressive.BaseProgressiveStreamingService.ProcessRequest(StreamRequest request, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void AttachMediaSourceInfo(Emby.Server.MediaEncoding.Encoder.EncodingJobInfo, MediaBrowser.Model.Dto.MediaSourceInfo, System.String, MediaBrowser.Controller.MediaEncoding.IFfmpegManager) I hope this get fixed ... or how I can add the items metadata instead of playing one by one on web client? Hmm, yes. We should be able to resolve this I would think.
ebr 16334 Posted August 15, 2022 Posted August 15, 2022 Hi. The Roku crash should be resolved in the next release of the app. Thanks.
jathe 9 Posted August 24, 2022 Author Posted August 24, 2022 Hi, testing m3u tunner. Any way to disable or block the automatic image creation for labels or tags in m3u list categories? This really make very bad icons for tags.
Luke 42241 Posted August 25, 2022 Posted August 25, 2022 17 hours ago, jathe said: Hi, testing m3u tunner. Any way to disable or block the automatic image creation for labels or tags in m3u list categories? This really make very bad icons for tags. Hi, currently, no, but there's no reason that such an option like that couldn't be added.
