Cheesegeezer 3104 Posted July 8, 2022 Posted July 8, 2022 5 hours ago, rbjtech said: Have a look at Vantage Point in the Plugins - it's the Cinema Intro feature on steroids and can probably do exactly what you want and more ... @Cheesegeezer Thanks Rich, my plan was to overhaul the plugin and make it more user intuitive. At the moment there are so many options to contend it’s quite a struggle to figure out what you have just created. it works great but dang…. You need a notepad to plan an execute lol
ebr 16307 Posted July 9, 2022 Posted July 9, 2022 15 hours ago, Cheesegeezer said: At the moment there are so many options to contend it’s quite a struggle to figure out what you have just created.
Carlo 4561 Posted July 9, 2022 Posted July 9, 2022 21 hours ago, Luke said: @cayars can improve the help article but you don't tag the intro, you tag the library item, and then the intro file name just matches the tag. Not sure exactly what needs updating in the KB article as it covers this already. Maybe it's a first time use issue in general, but anyone who has intros working for codecs should be able to easily ad tags and use that will little problem as well. Examples are shown already for codecs and tags. 20 hours ago, rbjtech said: Have a look at Vantage Point in the Plugins - it's the Cinema Intro feature on steroids and can probably do exactly what you want and more ... @Cheesegeezer That is a great way to describe it! If you're needs are more than playing a custom intro; intro based on a tag or codec; or playing a trailer before the "main movie", I'd definitely recommend looking at VantagePoint as it offers a great deal of functionality. Cinema Intro can be setup very quickly delivering a custom into and trailer preview with the greatest time needed for creating a directory and coping an into file(s) to it, then setting this directory in the Cinema Into GUI. With the custom directory already in place it's a 30 second setup. Vantage Point on the other hand is going to take some time to learn how it works and plan what you want to do. It can do so many things it gives you "option anxiety" You can literally spend hours playing around with different setups and get distracted quickly, so it helps to stay focused on a specific outcome from the start to get that working. Then go back and play some more.
Cheesegeezer 3104 Posted July 9, 2022 Posted July 9, 2022 59 minutes ago, ebr said: I know, i'm going to rewrite it very soon, to allow for the user to make their own journey. hahaha 3
