Vicpa 612 Posted July 8, 2022 Posted July 8, 2022 51 minutes ago, wordlover said: @Vicpa Please look at the example this thread started with. There is no rational reason the usages Of and of should sort separately. I did. Your tags are wrong. Change them. Garbage in - Garbage out.
Luke 42301 Posted July 8, 2022 Posted July 8, 2022 19 minutes ago, Vicpa said: @Luke WTF: this guys tags are wrong. I hope this is thoroughly tested or we could end up with more shit . It is a shame the emby keeps getting dumbed down.. Some sorting is case sensitive which it should never have been. 1
Vicpa 612 Posted July 8, 2022 Posted July 8, 2022 Hi @Luke Which ones are you going to change? I have a copy of my music library on a beta install. How should I test? @wordlover I am sure you are going to test, other than Brad, what are your cases/examples will you look at to verify?
Luke 42301 Posted July 8, 2022 Posted July 8, 2022 1 minute ago, Vicpa said: Hi @Luke Which ones are you going to change? I have a copy of my music library on a beta install. How should I test? @wordlover I am sure you are going to test, other than Brad, what are your cases/examples will you look at to verify? You can use happy2play's example as a perfect test, with any kind of library, setting the sort title on two different items and seeing which ones come out ahead.
Luke 42301 Posted July 12, 2022 Posted July 12, 2022 This is in 4.8.0.4 and we'll backport it to a 4.7 maintenance release. Thanks. 1
