Karoot 3 Posted July 7, 2022 Posted July 7, 2022 I accidentally changed my local port to 80 and now I cannot access the server....how can I undo or fix this?
Happy2Play 9800 Posted July 7, 2022 Posted July 7, 2022 What platform, but you will probably have to edit the system.xml directly.
Karoot 3 Posted July 7, 2022 Author Posted July 7, 2022 56 minutes ago, Happy2Play said: What platform, but you will probably have to edit the system.xml directly. I wiped the Emby configs via uninstall/reinstall and fixed it. Sorry guys.
caffeineshock 18 Posted July 8, 2022 Posted July 8, 2022 (edited) if your server has a GUI: go on host (or any device thats in the same network if your firewall does not block this) -> open browser -> 127.0.0.1:80 -> log in and change the setting you want if not: as happy2play told, edit the config files and restart server Edited July 8, 2022 by caffeineshock
