santo 1 Posted July 7, 2022 Posted July 7, 2022 Hi I'm not seeing Series and Movie information in the guide for Live TV - should I? At the moment I only get the channel logo. When I record a series it appears for the recording only. Using XMLTV guide feed generated from Shedules Direct. Live TV using ServerWMC. Episode and Series numbers coming through ok. Thanks
Luke 42243 Posted July 7, 2022 Posted July 7, 2022 Hi there, can you please go over an example? Thanks.
santo 1 Posted July 9, 2022 Author Posted July 9, 2022 Hi Thanks for the follow-up. For some reason it now seems to be working. The only thing that has changed is that I've subscribed membership to schedules direct and there is no longer a warning in the XMLT file. Are the series and movies poster images in the XMLT for the guide or does Emby lookup and download? Cheers
Luke 42243 Posted July 9, 2022 Posted July 9, 2022 Quote Are the series and movies poster images in the XMLT for the guide or does Emby lookup and download? Hi, it gets those images from the xmltv, so it would have to contain them.
santo 1 Posted July 10, 2022 Author Posted July 10, 2022 Ok. Thanks. It must have changed with the XMLTV feed subscription change then. 1
