roaku 842 Posted July 6, 2022 Posted July 6, 2022 (edited) I guess it's my turn for this one. I manually updated to 4.7.5. Now Emby will not start. I've rebooted and verified that the emby user has read/write access to the Emby directory. The latest Emby log is from the shutdown before the update. I can't find anything interesting in /var/log. Edited July 6, 2022 by roaku
Luke 42243 Posted July 6, 2022 Posted July 6, 2022 HI, can you try running from ssh: Then supply the terminal output. Thanks.
roaku 842 Posted July 6, 2022 Author Posted July 6, 2022 2 minutes ago, Luke said: HI, can you try running from ssh: Then supply the terminal output. Thanks. "Segmentation fault"
roaku 842 Posted July 6, 2022 Author Posted July 6, 2022 4 minutes ago, Luke said: When did you download the 4.7.5 update? About an hour ago.
Luke 42243 Posted July 6, 2022 Posted July 6, 2022 OK I've passed this onto our Synology packaging developer for review. Thanks. 1
roaku 842 Posted July 6, 2022 Author Posted July 6, 2022 (edited) 17 minutes ago, Luke said: And are you not able to update to DSM 7? My model technically supports it but is under-powered and DSM7 doesn't offer anything I'm particularly interested in to make it worth the hassle of migrating Emby and other packages. 'Emby is broken on DSM6' is just about the only condition that might make me upgrade...or switch to a standalone linux box for my Emby server. Edited July 6, 2022 by roaku
heffeque 78 Posted July 7, 2022 Posted July 7, 2022 1 hour ago, roaku said: My model technically supports it but is under-powered and DSM7 doesn't offer anything I'm particularly interested in to make it worth the hassle of migrating Emby and other packages. 'Emby is broken on DSM6' is just about the only condition that might make me upgrade...or switch to a standalone linux box for my Emby server. Actually, DSM 7/7.1 uses less RAM than DSM6. For the sake of snappiness, I recommend DSM7.1 quite a bit. 7.1 is also pretty great at managing SSD cache (not your case, but just wanted to point it out).
alucryd 318 Posted July 7, 2022 Posted July 7, 2022 @roaku Can you please run the following via SSH? It's to verify you have the fixed package indeed. ls -lah /var/packages/EmbyServer/target/lib/ Please let us know if you still have issues if you decide to upgrade to DSM7, I haven't compared memory usage but less can only be a good thing.
roaku 842 Posted July 7, 2022 Author Posted July 7, 2022 5 hours ago, alucryd said: @roaku Can you please run the following via SSH? It's to verify you have the fixed package indeed. ls -lah /var/packages/EmbyServer/target/lib/ Please let us know if you still have issues if you decide to upgrade to DSM7, I haven't compared memory usage but less can only be a good thing. total 61M drwxr-xr-x 2 root root 4.0K Jun 28 15:29 . drwxr-xr-x 9 root root 4.0K Jul 6 22:49 .. lrwxrwxrwx 1 root root 23 Jun 28 15:29 libavcodec.so -> libavcodec.so.59.21.100 lrwxrwxrwx 1 root root 23 Jun 28 15:29 libavcodec.so.59 -> libavcodec.so.59.21.100 -rwxr-xr-x 1 root root 14M Jun 28 15:29 libavcodec.so.59.21.100 lrwxrwxrwx 1 root root 23 Jun 28 15:29 libavdevice.so -> libavdevice.so.59.5.100 lrwxrwxrwx 1 root root 23 Jun 28 15:29 libavdevice.so.59 -> libavdevice.so.59.5.100 -rwxr-xr-x 1 root root 370K Jun 28 15:29 libavdevice.so.59.5.100 lrwxrwxrwx 1 root root 23 Jun 28 15:29 libavfilter.so -> libavfilter.so.8.25.100 lrwxrwxrwx 1 root root 23 Jun 28 15:29 libavfilter.so.8 -> libavfilter.so.8.25.100 -rwxr-xr-x 1 root root 3.7M Jun 28 15:29 libavfilter.so.8.25.100 lrwxrwxrwx 1 root root 24 Jun 28 15:29 libavformat.so -> libavformat.so.59.17.100 lrwxrwxrwx 1 root root 24 Jun 28 15:29 libavformat.so.59 -> libavformat.so.59.17.100 -rwxr-xr-x 1 root root 4.0M Jun 28 15:29 libavformat.so.59.17.100 lrwxrwxrwx 1 root root 22 Jun 28 15:29 libavutil.so -> libavutil.so.57.19.100 lrwxrwxrwx 1 root root 22 Jun 28 15:29 libavutil.so.57 -> libavutil.so.57.19.100 -rwxr-xr-x 1 root root 422K Jun 28 15:29 libavutil.so.57.19.100 -rwxr-xr-x 1 root root 78K Jun 28 15:29 libbcm_host.so -rwxr-xr-x 1 root root 164K Jun 28 15:29 libbrcmEGL.so -rwxr-xr-x 1 root root 82K Jun 28 15:29 libbrcmGLESv2.so lrwxrwxrwx 1 root root 17 Jun 28 15:29 libcom_err.so -> libcom_err.so.3.0 lrwxrwxrwx 1 root root 17 Jun 28 15:29 libcom_err.so.3 -> libcom_err.so.3.0 -rwxr-xr-x 1 root root 9.3K Jun 28 15:29 libcom_err.so.3.0 -rwxr-xr-x 1 root root 67K Jun 28 15:29 libcontainers.so lrwxrwxrwx 1 root root 16 Jun 28 15:29 libcrypto.so -> libcrypto.so.1.1 -rwxr-xr-x 1 root root 1.5M Jun 28 15:29 libcrypto.so.1.1 lrwxrwxrwx 1 root root 16 Jun 28 15:29 libcurl.so -> libcurl.so.4.7.0 lrwxrwxrwx 1 root root 16 Jun 28 15:29 libcurl.so.4 -> libcurl.so.4.7.0 -rwxr-xr-x 1 root root 275K Jun 28 15:29 libcurl.so.4.7.0 lrwxrwxrwx 1 root root 11 Jun 28 15:29 libdrm.so -> libdrm.so.2 lrwxrwxrwx 1 root root 15 Jun 28 15:29 libdrm.so.2 -> libdrm.so.2.4.0 -rwxr-xr-x 1 root root 46K Jun 28 15:29 libdrm.so.2.4.0 lrwxrwxrwx 1 root root 23 Jun 28 15:29 libfontconfig.so -> libfontconfig.so.1.12.0 lrwxrwxrwx 1 root root 23 Jun 28 15:29 libfontconfig.so.1 -> libfontconfig.so.1.12.0 -rwxr-xr-x 1 root root 566K Jun 28 15:29 libfontconfig.so.1.12.0 lrwxrwxrwx 1 root root 13 Jun 28 15:29 libgcc_s.so -> libgcc_s.so.1 -rwxr-xr-x 1 root root 92K Jun 28 15:29 libgcc_s.so.1 lrwxrwxrwx 1 root root 21 Jun 28 15:29 libgssapi_krb5.so -> libgssapi_krb5.so.2.2 lrwxrwxrwx 1 root root 21 Jun 28 15:29 libgssapi_krb5.so.2 -> libgssapi_krb5.so.2.2 -rwxr-xr-x 1 root root 159K Jun 28 15:29 libgssapi_krb5.so.2.2 lrwxrwxrwx 1 root root 18 Jun 28 15:29 libicudata.so -> libicudata.so.68.2 lrwxrwxrwx 1 root root 18 Jun 28 15:29 libicudata.so.68 -> libicudata.so.68.2 -rwxr-xr-x 1 root root 28M Jun 28 15:29 libicudata.so.68.2 lrwxrwxrwx 1 root root 18 Jun 28 15:29 libicui18n.so -> libicui18n.so.68.2 lrwxrwxrwx 1 root root 18 Jun 28 15:29 libicui18n.so.68 -> libicui18n.so.68.2 -rwxr-xr-x 1 root root 1.8M Jun 28 15:29 libicui18n.so.68.2 lrwxrwxrwx 1 root root 16 Jun 28 15:29 libicuio.so -> libicuio.so.68.2 lrwxrwxrwx 1 root root 16 Jun 28 15:29 libicuio.so.68 -> libicuio.so.68.2 -rwxr-xr-x 1 root root 30K Jun 28 15:29 libicuio.so.68.2 lrwxrwxrwx 1 root root 18 Jun 28 15:29 libicutest.so -> libicutest.so.68.2 lrwxrwxrwx 1 root root 18 Jun 28 15:29 libicutest.so.68 -> libicutest.so.68.2 -rwxr-xr-x 1 root root 46K Jun 28 15:29 libicutest.so.68.2 lrwxrwxrwx 1 root root 16 Jun 28 15:29 libicutu.so -> libicutu.so.68.2 lrwxrwxrwx 1 root root 16 Jun 28 15:29 libicutu.so.68 -> libicutu.so.68.2 -rwxr-xr-x 1 root root 123K Jun 28 15:29 libicutu.so.68.2 lrwxrwxrwx 1 root root 16 Jun 28 15:29 libicuuc.so -> libicuuc.so.68.2 lrwxrwxrwx 1 root root 16 Jun 28 15:29 libicuuc.so.68 -> libicuuc.so.68.2 -rwxr-xr-x 1 root root 1.2M Jun 28 15:29 libicuuc.so.68.2 lrwxrwxrwx 1 root root 18 Jun 28 15:29 libk5crypto.so -> libk5crypto.so.3.1 lrwxrwxrwx 1 root root 18 Jun 28 15:29 libk5crypto.so.3 -> libk5crypto.so.3.1 -rwxr-xr-x 1 root root 126K Jun 28 15:29 libk5crypto.so.3.1 lrwxrwxrwx 1 root root 14 Jun 28 15:29 libkrb5.so -> libkrb5.so.3.3 lrwxrwxrwx 1 root root 14 Jun 28 15:29 libkrb5.so.3 -> libkrb5.so.3.3 -rwxr-xr-x 1 root root 480K Jun 28 15:29 libkrb5.so.3.3 lrwxrwxrwx 1 root root 21 Jun 28 15:29 libkrb5support.so -> libkrb5support.so.0.1 lrwxrwxrwx 1 root root 21 Jun 28 15:29 libkrb5support.so.0 -> libkrb5support.so.0.1 -rwxr-xr-x 1 root root 26K Jun 28 15:29 libkrb5support.so.0.1 -rwxr-xr-x 1 root root 45K Jun 28 15:29 libmmal_components.so -rwxr-xr-x 1 root root 57K Jun 28 15:29 libmmal_core.so -rwxr-xr-x 1 root root 9.7K Jun 28 15:29 libmmal.so -rwxr-xr-x 1 root root 63K Jun 28 15:29 libmmal_util.so -rwxr-xr-x 1 root root 35K Jun 28 15:29 libmmal_vc_client.so -rwxr-xr-x 1 root root 24K Jun 28 15:29 libopenmaxil.so lrwxrwxrwx 1 root root 23 Jun 28 15:29 libpostproc.so -> libpostproc.so.56.4.100 lrwxrwxrwx 1 root root 23 Jun 28 15:29 libpostproc.so.56 -> libpostproc.so.56.4.100 -rwxr-xr-x 1 root root 26K Jun 28 15:29 libpostproc.so.56.4.100 lrwxrwxrwx 1 root root 17 Jun 28 15:29 libSkiaSharp.so -> libSkiaSharp.so.2 lrwxrwxrwx 1 root root 20 Jun 28 15:29 libSkiaSharp.so.2 -> libSkiaSharp.so.80.2 -rwxr-xr-x 1 root root 2.4M Jun 28 15:29 libSkiaSharp.so.80.2 lrwxrwxrwx 1 root root 19 Jun 28 15:29 libsqlite3.so -> libsqlite3.so.0.8.6 lrwxrwxrwx 1 root root 19 Jun 28 15:29 libsqlite3.so.0 -> libsqlite3.so.0.8.6 -rwxr-xr-x 1 root root 585K Jun 28 15:29 libsqlite3.so.0.8.6 lrwxrwxrwx 1 root root 13 Jun 28 15:29 libssl.so -> libssl.so.1.1 -rwxr-xr-x 1 root root 305K Jun 28 15:29 libssl.so.1.1 lrwxrwxrwx 1 root root 19 Jun 28 15:29 libstdc++.so -> libstdc++.so.6.0.25 lrwxrwxrwx 1 root root 19 Jun 28 15:29 libstdc++.so.6 -> libstdc++.so.6.0.25 -rwxr-xr-x 1 root root 826K Jun 28 15:29 libstdc++.so.6.0.25 lrwxrwxrwx 1 root root 24 Jun 28 15:29 libswresample.so -> libswresample.so.4.4.100 lrwxrwxrwx 1 root root 24 Jun 28 15:29 libswresample.so.4 -> libswresample.so.4.4.100 -rwxr-xr-x 1 root root 62K Jun 28 15:29 libswresample.so.4.4.100 lrwxrwxrwx 1 root root 21 Jun 28 15:29 libswscale.so -> libswscale.so.6.5.100 lrwxrwxrwx 1 root root 21 Jun 28 15:29 libswscale.so.6 -> libswscale.so.6.5.100 -rwxr-xr-x 1 root root 282K Jun 28 15:29 libswscale.so.6.5.100 lrwxrwxrwx 1 root root 16 Jun 28 15:29 libuuid.so -> libuuid.so.1.3.0 lrwxrwxrwx 1 root root 16 Jun 28 15:29 libuuid.so.1 -> libuuid.so.1.3.0 -rwxr-xr-x 1 root root 18K Jun 28 15:29 libuuid.so.1.3.0 -rwxr-xr-x 1 root root 22K Jun 28 15:29 libvchiq_arm.so -rwxr-xr-x 1 root root 39K Jun 28 15:29 libvcos.so -rwxr-xr-x 1 root root 26K Jun 28 15:29 libvcsm.so lrwxrwxrwx 1 root root 14 Jun 28 15:29 libz.so -> libz.so.1.2.11 lrwxrwxrwx 1 root root 14 Jun 28 15:29 libz.so.1 -> libz.so.1.2.11 -rwxr-xr-x 1 root root 58K Jun 28 15:29 libz.so.1.2.11
alucryd 318 Posted July 8, 2022 Posted July 8, 2022 @roakuThanks, no trace of glibc so you do have the correct package. What's the last package that worked for you? This one is essentially the same as the previous 4.6 line and early 4.7 packages. Also did you try the latest beta, if your kernel version is above 3.2 could you give it a try?
roaku 842 Posted July 8, 2022 Author Posted July 8, 2022 2 hours ago, alucryd said: @roakuThanks, no trace of glibc so you do have the correct package. What's the last package that worked for you? This one is essentially the same as the previous 4.6 line and early 4.7 packages. Also did you try the latest beta, if your kernel version is above 3.2 could you give it a try? I was upgrading from 4.7.2, I believe. I had no issues upgrading from 4.6 to 4.7 about a month after 4.7 was released. Assuming you mean Linux kernel, that's at 3.10.105.
Solution alucryd 318 Posted July 8, 2022 Solution Posted July 8, 2022 1 hour ago, roaku said: I was upgrading from 4.7.2, I believe. I had no issues upgrading from 4.6 to 4.7 about a month after 4.7 was released. Assuming you mean Linux kernel, that's at 3.10.105. Thanks for your answers. Can you give the latest beta a try then? With the stable package as it is today, the only thing that can segfault so early is the dotnet runtime itself. We've been steadily losing arm devices over the years to what seems to be that same issue, I'm hoping the newer glibc shipped in the beta can alleviate that.
roaku 842 Posted July 8, 2022 Author Posted July 8, 2022 5 minutes ago, alucryd said: Thanks for your answers. Can you give the latest beta a try then? With the stable package as it is today, the only thing that can segfault so early is the dotnet runtime itself. We've been steadily losing arm devices over the years to what seems to be that same issue, I'm hoping the newer glibc shipped in the beta can alleviate that. Ok. I'll try this evening (+7 hours or so).
roaku 842 Posted July 8, 2022 Author Posted July 8, 2022 (edited) @alucryd The 4.8 beta is working for me. The server started up and everything is working normally (so far). Thanks. Edited July 8, 2022 by roaku 1
alucryd 318 Posted July 9, 2022 Posted July 9, 2022 Great, thanks for the feedback! I'm glad to hear that, we might be able to reclaim devices we had to move to mono due to that issue, provided they have a kernel above 3.2. 1
