ffwell 5 Posted July 14, 2022 Posted July 14, 2022 On 7/7/2022 at 3:31 AM, ebr said: Yes, thanks. It appears your system doesn't support that audio format so it is internally mixing it down to stereo. This would cause a loss of dynamic range and potentially make it sound quieter. Are you playing just on the TV speakers? This is indeed the reason. But the sound of the same film in Kodi and other players is also normal. Is there a way to solve it?
ebr 16337 Posted July 14, 2022 Posted July 14, 2022 7 minutes ago, ffwell said: This is indeed the reason. But the sound of the same film in Kodi and other players is also normal. Is there a way to solve it? Is it better if you change the audio option to "Mix down to stereo"?
ffwell 5 Posted July 14, 2022 Posted July 14, 2022 (edited) 6 minutes ago, ebr said: Is it better if you change the audio option to "Mix down to stereo"? yes,Select auto or Mix down to stereo Is the same effect。 Edited July 14, 2022 by ffwell
Luke 42245 Posted July 15, 2022 Posted July 15, 2022 HI, can you try sideloading our standard android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks !
