Mr_Scumbag 8 Posted July 5, 2022 Posted July 5, 2022 This seems to happen every few versions of Emby server, which is why I usually hold off on updating for many months once this issue stops after upgrading to a "good" version. It's very frustrating and has been occurring for years. I'm using the latest version of Chrome and Emby server. After Chromecasting, the media will continue playing as normal, but anywhere between a few minutes to a hour after playing the media, the Web app will stop communicating with the Chromecast, meaning that the status bar will stop moving and showing how far into the media it is, and all controls (pause, next, previous, etc) will stop responding, but the media continues to play on the Chromecast. The only way to resolve this is to disconnect and reconnect to the Chromecast or (sometimes) to refresh the Emby Web page, although about 50% of the time, refreshing the page will immediately disconnect the Chromecast, stopping media. Importantly, I also use the web app with a different server running an older version, and this issue very rarely ever occurs, so it certainly seems to be related to the version. Why it's a much bigger issue in some versions than others is worth investigating, I think. I'm interested in hearing from others who Chromecast from Emby Web in Chrome. I imagine it's not a particularly common setup, but are there others experiencing this issue?
Luke 42241 Posted July 5, 2022 Posted July 5, 2022 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Mr_Scumbag 8 Posted July 21, 2022 Author Posted July 21, 2022 Thanks for your response and sorry for my delayed reply. I had to wait for the issue to occur again in a time window where I was easily able to find the right part of the log. The issue described above has just occurred again, although slightly differently in that instead of the stream still playing on the TV, it has completely frozen and the controls on the PC are not working either. This happened about 3min and 50 seconds into playing a movie. The log is small enough to post here: 2022-07-21 10:31:17.982 Info Server: http/1.1 Response 204 to 192.168.1.107. Time: 2ms. http://192.168.1.109:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Chromecast&X-Emby-Device-Name=Chromecast&X-Emby-Device-Id=chromecast_1658324284942&X-Emby-Client-Version=2.1.0&reqformat=json 2022-07-21 10:31:22.257 Error PortMapper: Error in GetSpecificMappingAsync *** Error Report *** Version: 4.7.5.0 Command line: C:\Users\dsktp01\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.19043 Framework: .NET 6.0.5 OS/Process: x64/x64 Runtime: C:/Users/dsktp01/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 12 Data path: C:\Users\dsktp01\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\dsktp01\AppData\Roaming\Emby-Server\system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.IO.IOException: The response ended prematurely. at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Mono.Nat.Upnp.UpnpNatDevice.GetSpecificMappingAsync(Protocol protocol, Int32 publicPort, CancellationToken cancellationToken) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMap(Mapping mapping, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() InnerException: System.IO.IOException: The response ended prematurely. Source: System.Net.Http TargetSite: Void MoveNext() at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) 2022-07-21 10:31:22.263 Error HttpClient: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"> <s:Body> <s:Fault> <faultcode>s:Client</faultcode> <faultstring>UPnPError</faultstring> <detail> <UPnPError xmlns="urn:schemas-upnp-org:control-1-0"> <errorCode>402</errorCode> <errorDescription>Invalid Args</errorDescription> </UPnPError> </detail> </s:Fault> </s:Body> </s:Envelope>
Luke 42241 Posted July 21, 2022 Posted July 21, 2022 @Mr_Scumbag can you please attach the complete emby server log (and the ffmpeg log if there was one)? Thanks !
Mr_Scumbag 8 Posted July 21, 2022 Author Posted July 21, 2022 I have attached the requested log files. As the issue occurred at around 10:30am, I'm not sure the FFMPEG log will contain anything useful, though. embyserver.txt ffmpeg-remux-16e13dd2-144c-48f0-b502-247d04239a4b_1.txt
Mr_Scumbag 8 Posted July 27, 2022 Author Posted July 27, 2022 @Luke Is there any indication of the cause of this issue in the logs I provided?
Luke 42241 Posted August 5, 2022 Posted August 5, 2022 Hi, I don't see anything obvious. Have you updated to Emby Server 4.7.6? Are you still running into this?
Mr_Scumbag 8 Posted August 12, 2022 Author Posted August 12, 2022 @Luke I have updated and it is still occurring. It seems to be less frequent, but it's hard to tell without more time with the new version.
Mr_Scumbag 8 Posted August 12, 2022 Author Posted August 12, 2022 Update: Seems to be happening more frequently now. I haven't been able to watch anything (45 min episodes) all the way through without it occurring since I updated.
Mr_Scumbag 8 Posted August 24, 2022 Author Posted August 24, 2022 (edited) Yes, and other issues. Sometimes the video just stops altogether on the TV as well as the webapp. The only way to recover it is to un-chromecast then re-chromecast, but now sometimes I'm not even able to un-chromecast Emby which is a new wrinkle I've not encountered for any app before. The only way to fix this when it happens it to chromecast something else to the TV. Othertimes, the stream will start pausing or stuttering for no obvious reason. Disk I/O is fine, wireless is fine, network traffic is fine. un-chromecasting, re-chromecasting and then resuming the video will fix the issue. Sometimes for the remainder of the video, sometimes only for 10-20 minutes. It's very random. I've decided to switch to Plex until the next major Emby update cause it's becoming too much of a hassle to babysit. Edited August 24, 2022 by Mr_Scumbag
Luke 42241 Posted September 16, 2022 Posted September 16, 2022 On 8/23/2022 at 11:49 PM, Mr_Scumbag said: Yes, and other issues. Sometimes the video just stops altogether on the TV as well as the webapp. The only way to recover it is to un-chromecast then re-chromecast, but now sometimes I'm not even able to un-chromecast Emby which is a new wrinkle I've not encountered for any app before. The only way to fix this when it happens it to chromecast something else to the TV. Othertimes, the stream will start pausing or stuttering for no obvious reason. Disk I/O is fine, wireless is fine, network traffic is fine. un-chromecasting, re-chromecasting and then resuming the video will fix the issue. Sometimes for the remainder of the video, sometimes only for 10-20 minutes. It's very random. I've decided to switch to Plex until the next major Emby update cause it's becoming too much of a hassle to babysit. Hi, did you see this? https://www.pcworld.com/article/871581/change-your-plex-password-right-now.html Anyway can you try this again?
Mr_Scumbag 8 Posted October 21, 2022 Author Posted October 21, 2022 Tried it again. It's worse than ever. Completely unusable while Chromecasting.
Luke 42241 Posted December 4, 2022 Posted December 4, 2022 @Mr_Scumbag are you still running into this?
Mr_Scumbag 8 Posted December 7, 2022 Author Posted December 7, 2022 It seems to be working properly now. That has happened before, though. Usually it lasts for a while until the issue starts occurring again after a new update. I guess all I can do is keep using it and see what happens. 1
Mr_Scumbag 8 Posted January 5, 2023 Author Posted January 5, 2023 Happening again. Constantly. Plex is working without a hitch.
