Guest Posted October 15, 2013 Posted October 15, 2013 Hello, I have couple DTS Demo blurays that I have converted to mkv and transferred to my server. I created a "Sound Demos" folder and organize the folder structure like this G:\Ryan\My Videos\Sound Demo's\DTS Blu-ray Demonstration Disc 14 In the DTS blu-ray... folder there are 15 sub folders each with a clip. the clip and folder name are the same. so for example G:\Ryan\My Videos\Sound Demo's\DTS Blu-ray Demonstration Disc 14/Band of Brothers/Band of Brothers.mkv Is there any place to find metadata for demo disks or do I have to create it myself? Thanks for any advice
Solution Cheesegeezer 3106 Posted October 16, 2013 Solution Posted October 16, 2013 MB would not probably search the right sites for your metadata. However sites that sell these demo discs may provide rich information regarding them which you can copy and paste into your movie.xml (or simply copy and paste an existing movie.xml and edit the necessary fields of data you wish to display). I would maybe have thought the DTS site might give this information or maybe amazon if they sell the sound demos. It's quite a niche market unfortunately, so grabbing metadata would be hard anyway unless there is an enthusiast forum or portal somewhere.
