KRONZO 20 Posted July 3, 2022 Posted July 3, 2022 HI I cant seem to get Native paths working , it keeps saying the ´file isn't available. all path are added correctly and i can play the files through kodi using native path but next-gen can't find em. I checked the log in kodi, and it says something about It can't resolve server name, but it's no problem bypassing emby app playback works fine Is this some limitation/bug in android on shield? I want to use native path mainly because of subtitles not being saved on app paths and there are some info in the file naming as well.
quickmic 1709 Posted July 3, 2022 Posted July 3, 2022 Send me a kodi.log an I'll check. I assume the native path reported from Emby server is not available on your Nvidia shield. Could be a network share issue, or invalid Emby server network path config.
