hemsimmons 0 Posted July 3, 2022 Posted July 3, 2022 It appears nothing has recording on my DVR since the middle of June. Attached is the latest log file showing recording errors today. I don't see anything that makes any sense to me to troubleshoot. Thanks for the help! embyserver (1).txt
Luke 42186 Posted July 3, 2022 Posted July 3, 2022 Hi, your HD Homerun is returning a 503 unavailable error when we try and open a live stream. Can you try rebooting the HDHR?
hemsimmons 0 Posted July 8, 2022 Author Posted July 8, 2022 I have rebooted the HD Homerun, restarted Emby, even tried to do some manual recordings --- nothing is recording still.
Luke 42186 Posted July 8, 2022 Posted July 8, 2022 15 minutes ago, hemsimmons said: I have rebooted the HD Homerun, restarted Emby, even tried to do some manual recordings --- nothing is recording still. Can you please provide a new server log example? Thanks.
hemsimmons 0 Posted July 8, 2022 Author Posted July 8, 2022 Here you go. Should have done that before, sorry. embyserver (2).txt
Luke 42186 Posted July 11, 2022 Posted July 11, 2022 On 7/8/2022 at 3:20 PM, hemsimmons said: Here you go. Should have done that before, sorry. embyserver (2).txt 717.18 kB · 0 downloads It's still the same. Do you know the IP address of your hdhr? Find that, then open up the HDHR web interface using: http://ip:5004 This allows you to click on a channel and then try to open a stream, which will just download in your browser as a ts file. Are you able to do that with the same channel you tried to use in Emby Server?
hemsimmons 0 Posted July 11, 2022 Author Posted July 11, 2022 Yes -- and there was a firmware update to install -- so I have done that -- then every channel I click on gave me "This page isn't working right now". So I ran "Detect channels" for it to start over and now it finds nothing Guess i have to go into the attic now and see what the heck has happened --- I haven't touched a thing but it's like the antenna isn't even up there. Not something I want to do in Mississippi in JULY .. yay me!
