wedgekc 12 Posted June 30, 2022 Posted June 30, 2022 It appears that all movies with 7.1 audio are transcoding with a direct play error on my android phone. Is that normal, I don't recall that being the case? Thanks. embyserver.txt transcode.txt
wedgekc 12 Posted August 1, 2022 Author Posted August 1, 2022 Is this fixed? I noticed the last 2/3 of Android updates over the last couple of weeks listed fixes for direct play errors but the direct play errors are still occurring. I'm on 3.2.61. Thanks.
Luke 42243 Posted August 1, 2022 Posted August 1, 2022 13 minutes ago, wedgekc said: Is this fixed? I noticed the last 2/3 of Android updates over the last couple of weeks listed fixes for direct play errors but the direct play errors are still occurring. I'm on 3.2.61. Thanks. Hi, can you please try this version of the android app: https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 And then provide a log from the app by following these instructions: Thanks !
wedgekc 12 Posted August 1, 2022 Author Posted August 1, 2022 Here is the Android log from with the updated version of the app. Thanks. 8a4e9ea3-3f2e-4c99-9720-432530e50c22.log
Luke 42243 Posted August 1, 2022 Posted August 1, 2022 Hmm. Can you provide a sample video for testing? Thanks.
Luke 42243 Posted August 5, 2022 Posted August 5, 2022 @wedgekc Can you please try the latest build from our website: https://emby.media/emby-for-android.html I believe this should be resolved now in 3.2.62+. Thanks.
wedgekc 12 Posted August 6, 2022 Author Posted August 6, 2022 4 hours ago, Luke said: I believe this should be resolved now in 3.2.62+. Thanks. Yes, it does resolve the issue. Thanks. 1
