Silvino 0 Posted June 30, 2022 Posted June 30, 2022 ENGLISH: I use the Portable Version of Emby on a 4TB External HD. Everything is there, mapped with the letter Y. Is it possible to implicitly inform the current drive letter in the libraries path? For example, if I connect this External HD to another computer, and this new computer gives the hardware the letter "D", there would be no way in Emby to use some variable of type %currentdriveletter% instead of me having to assign the letter Y to the External HD every time it was connected to a different PC? PORTUGUESE: Uso a Versão Portable do Emby em um HD Externo de 4 TB. Tudo fica nele, mapeado com a letra Y. É possível informar no path das bibliotecas, implicitamente, a letra do drive atual? Por exemplo, se conecto esse HD Externo em outro computador, e este novo computador concede ao hardware a letra "D", não haveria no Emby uma foram de usar alguma variável do tipo %currentdriveletter% em vez de eu ter que atribuir a letra Y ao HD Externo toda vez que ele fosse conectado em um PC diferente?
Abobader 3485 Posted June 30, 2022 Posted June 30, 2022 Hello Silvino, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42186 Posted June 30, 2022 Posted June 30, 2022 Hi, there is currently no way to do this, so you'll probably want to make sure it always gets the same drive letter. Either that or you'll have to update the library in Emby library setup when it changes.
Silvino 0 Posted July 1, 2022 Author Posted July 1, 2022 ENGLISH: And wouldn't there be a way to inform only the path, without the drive letter, and in these cases, Emby implies that it is the existing drive in the same path of the EmbyServer.exe executable? PORTUGUESE: E não haveria como informar apenas o path, sem a letra do drive, e nesses casos, o Emby subentender que se trata do drive existente no mesmo path do executável EmbyServer.exe?
Luke 42186 Posted July 2, 2022 Posted July 2, 2022 8 hours ago, Silvino said: ENGLISH: And wouldn't there be a way to inform only the path, without the drive letter, and in these cases, Emby implies that it is the existing drive in the same path of the EmbyServer.exe executable? PORTUGUESE: E não haveria como informar apenas o path, sem a letra do drive, e nesses casos, o Emby subentender que se trata do drive existente no mesmo path do executável EmbyServer.exe? There is currently no way to do that, but in future updates we plan to make it easier to move libraries from one location to another, and that should help with this when the drive letter changes.
ManuJapan89 2 Posted July 20, 2022 Posted July 20, 2022 i suggest to use windows disk management tool to change drive letter of the external disk from X(example) to what emby expect. a change made with disk management tool is permanent until you change again. 1
